Rackmount myServer - whole server unresponsive
Re: Rackmount myServer - whole server unresponsive
1 year 10 months ago
#3710
#3711
I've had something similar happen once, it was after a "host reboot". Nothing would respond, I think in my case it's referred to as a "kernel panic".
1 year 9 months ago
#3727
And it's happened again, exactly the same - myServer suddenly goes completely unresponsive to any communications until I yank the plug to power cycle it. And I still haven't sorted out plugging an HDMI lead into it...
It seems to be once a week roughly but I've only had my monitoring going just over a week so that's just based on my memory at the moment.
1 year 9 months ago
#3728
And the symptoms were the same - myServer appears (from the log) to have been running normally then spontaneously restarted but not properly as there's none of the normal log chatter until I unceremoniously yoink the power an hour later.
14/12/2024 21:09:35.09 · DEBUG · AndroidTV.TX: FireTV - dumpsys activity activities | grep "mResumedActivity"
14/12/2024 21:09:35.09 · DEBUG · AndroidTV.RX - FireTV <<    mResumedActivity: ActivityRecord{b152fe7 u0 com.amazon.tv.launcher/.deeplink.activity.DirectiveSearchResultsActivityDI t779}>>
14/12/2024 21:09:45.09 · DEBUG · AndroidTV.CheckAdb - Checking for ADB running
14/12/2024 21:09:45.09 · DEBUG · AndroidTV.CheckAdb - List of devices attached 192.168.1.144:55055 device 192.168.1.173:5555 device
14/12/2024 21:09:45.09 · DEBUG · AndroidTV.TX: FireTV - dumpsys display| grep "mScreenState"
14/12/2024 21:09:45.09 · DEBUG · AndroidTV.RX - FireTV <<  mScreenState=ON>>
14/12/2024 21:09:45.09 · DEBUG · AndroidTV.TX: FireTV - dumpsys activity activities | grep "mResumedActivity"
14/12/2024 21:09:46.09 · DEBUG · AndroidTV.RX - FireTV <<    mResumedActivity: ActivityRecord{b152fe7 u0 com.amazon.tv.launcher/.deeplink.activity.DirectiveSearchResultsActivityDI t779}>>
14/12/2024 21:09:56.09 · DEBUG · AndroidTV.CheckAdb - Checking for ADB running
14/12/2024 21:09:56.09 · DEBUG · AndroidTV.CheckAdb - List of devices attached 192.168.1.144:55055 device 192.168.1.173:5555 device
14/12/2024 21:09:56.09 · DEBUG · AndroidTV.TX: FireTV - dumpsys display| grep "mScreenState"
14/12/2024 21:09:56.09 · DEBUG · AndroidTV.RX - FireTV <<  mScreenState=ON>>
14/12/2024 21:09:56.09 · DEBUG · AndroidTV.TX: FireTV - dumpsys activity activities | grep "mResumedActivity"
14/12/2024 21:09:56.09 · DEBUG · AndroidTV.RX - FireTV <<    mResumedActivity: ActivityRecord{b152fe7 u0 com.amazon.tv.launcher/.deeplink.activity.DirectiveSearchResultsActivityDI t779}>>
14/12/2024 21:09:18.09 · INFO · Server.InitServer - myServer is Initializing
14/12/2024 21:09:19.09 · INFO · Server.InitServer - myServer is starting at 12/14/2024 21:09:19
14/12/2024 21:09:19.09 · DEBUG · SVars.LoadVariables - Restoring Server Variables from database.
14/12/2024 21:09:19.09 · TRACE · SVars.ResetRules - Resetting rules flags.
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - Serverpath is /home/allonis/applications/myServer
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - WebRoot is /home/allonis/applications/myServer/wwwroot
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - ImagesRoot is /home/allonis/applications/myServer/wwwroot/images
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - LogsRoot is /home/allonis/applications/myServer/logs
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - BackupsRroot is /home/allonis/applications/myServer/backups
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - DataRoot is /home/allonis/applications/myServer/data
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - AppsRoot is /home/allonis/applications/myServer/apps
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - DriversRoot is /home/allonis/applications/myServer/drivers
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - DownloadsRoot is /home/allonis/applications/myServer/downloads
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - MediaFilesRoot is /home/allonis/applications/myServer/wwwroot/media
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - MediaFilesRootAlias is /mediafiles
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - Server OS is Debian GNU/Linux 12 (bookworm)
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - Runtime Identifier is linux-arm64
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - Processor Architecture is Arm64
14/12/2024 21:09:19.09 · DEBUG · Server.InitServer - Server Architecture is Arm64
14/12/2024 21:09:19.09 · DEBUG · Server.IPV4 - 192.168.1.101
14/12/2024 21:09:24.09 · INFO · Server.InitServer - Serial Number xxx
14/12/2024 21:09:24.09 · INFO · Server.InitServer - MAC Address xxx
14/12/2024 21:09:24.09 · INFO · Licensing.ValidateActivationCode - Validating myServer License
14/12/2024 21:09:24.09 · INFO · Licensing.ValidateActivationCode - Permanent myServer license. myServer has full functionality.
14/12/2024 21:09:24.09 · INFO · Server.InitServer - myServer activated and not overdrawn
14/12/2024 21:09:26.09 · INFO · Server.InitServer - Teamviewer ID is xxx
14/12/2024 21:09:26.09 · INFO · Server.InitServer - myServer xxx Licensed Units 175
14/12/2024 21:09:26.09 · INFO · Server.InitServer - myServer xxx is listening on all IP addresses
14/12/2024 21:09:26.09 · INFO · Server.InitServer - myServer xxx primary IP address is 192.168.1.101
14/12/2024 21:09:26.09 · INFO · Server.InitServer - myServer is listening on port 80
14/12/2024 21:09:26.09 · DEBUG · Server.mDnsHandler - IP address 192.168.1.101
14/12/2024 21:09:26.09 · DEBUG · Server.mDnsHandler - discovered NIC 'eth0'
14/12/2024 21:09:26.09 · DEBUG · Server.InitServer - Loading 6 Device Drivers...
14/12/2024 21:09:26.09 · DEBUG · Server.InitServer - Loading Driver AndroidTV
14/12/2024 21:09:27.09 · DEBUG · Server.InitServer - Loading Driver GenericIR
14/12/2024 21:09:27.09 · DEBUG · Server.InitServer - Loading Driver YamahaAVR
14/12/2024 21:09:27.09 · DEBUG · Server.InitServer - Loading Driver CableTV
14/12/2024 21:09:27.09 · DEBUG · Server.InitServer - Loading Driver Kodi
14/12/2024 21:09:27.09 · DEBUG · Server.InitServer - Loading Driver TVIR
14/12/2024 21:09:27.09 · DEBUG · Server.InitServer - Loading 1 Applets...
14/12/2024 21:09:27.09 · DEBUG · Server.InitServer - Loading Applet Weather
14/12/2024 21:09:27.09 · INFO · SystemTimers.Heartbeat - Starting Heartbeat Timer  12/14/2024 21:09:27
14/12/2024 21:09:27.09 · DEBUG · Server has finished initialization...
14/12/2024 22:19:47.19 · DEBUG · YamahaAVR.NetConnect - Device 23 has connected.
14/12/2024 22:19:48.19 · DEBUG · AndroidTV.Init - Started a new ADB daemon
14/12/2024 22:19:48.19 · DEBUG · AndroidTV.Exist? - [/home/allonis/applications/myServer/data/tvapps.json]
14/12/2024 22:19:48.19 · DEBUG · AndroidTV.Exist? - [217]
14/12/2024 22:19:54.19 · DEBUG · Server.WebCmd - All~Toast|Info~Server Restart~myServer has been restarted and is resuming normal operations.~5000
14/12/2024 22:19:58.19 · DEBUG · AndroidTV.OnDeviceConnected - The device {192.168.1.144:55055} has connected
14/12/2024 22:19:58.19 · DEBUG · AndroidTV.OnDeviceConnected - The device {192.168.1.173:5555} has connected
14/12/2024 22:20:01.20 · DEBUG · Server.doCommand - MqttPublish|zigbee2mqtt/Kitchen LED strip/set~{{zigbee2mqtt_kitchen switchstate}} from
14/12/2024 22:20:01.20 · DEBUG · Server.doCommand - MqttPublish|zigbee2mqtt/Kitchen LED strip/set~OFF
14/12/2024 22:20:08.20 · DEBUG · AndroidTV.CheckAdb - Checking for ADB running
14/12/2024 22:20:08.20 · DEBUG · AndroidTV.CheckAdb - List of devices attached 192.168.1.144:55055 device 192.168.1.173:5555 offline
1 year 9 months ago
#3730
And again! So it isn't every week. This time I've got HDMI plugged in. The video output is still showing the Pi desktop with the clock stuck at the time the whole system locked up (21:32). No response to local mouse or keyboard plugged in to the Pi - had to yank the power again. It looks like the whole Pi might be spontaneously rebooting but as most log files start from boot it's difficult to say after I've done a power cycle. Anywhere I can look to confirm or deny this?
This is really pissing me off. All I want is a rock solid reliable remote control system. Home automation is just a nice extra.
16/12/2024 21:32:28.32 · DEBUG · Server.InitServer - Loading Driver Kodi
16/12/2024 21:32:28.32 · DEBUG · Server.InitServer - Loading Driver TVIR
16/12/2024 21:32:28.32 · DEBUG · Server.InitServer - Loading 1 Applets...
16/12/2024 21:32:28.32 · DEBUG · Server.InitServer - Loading Applet Weather
16/12/2024 21:32:28.32 · INFO · SystemTimers.Heartbeat - Starting Heartbeat Timer 12/16/2024 21:32:28
16/12/2024 21:32:28.32 · DEBUG · Server has finished initialization...
16/12/2024 21:51:14.51 · DEBUG · YamahaAVR.NetConnect - Device 23 has connected.
16/12/2024 21:51:14.51 · DEBUG · AndroidTV.Init - Started a new ADB daemon
16/12/2024 21:51:14.51 · DEBUG · AndroidTV.Exist? - [/home/allonis/applications/myServer/data/tvapps.json]
16/12/2024 21:51:14.51 · DEBUG · AndroidTV.Exist? - [217]
16/12/2024 21:51:20.51 · DEBUG · Server.WebCmd - All~Toast|Info~Server Restart~myServer has been restarted and is resuming normal operations.~5000
16/12/2024 21:51:25.51 · DEBUG · AndroidTV.OnDeviceConnected - The device {192.168.1.144:55055} has connected
16/12/2024 21:51:25.51 · DEBUG · AndroidTV.OnDeviceConnected - The device {192.168.1.173:5555} has connected
16/12/2024 21:51:29.51 · DEBUG · Server.doCommand - MqttPublish|zigbee2mqtt/Kitchen LED strip/set~{{zigbee2mqtt_kitchen switchstate}} from
1 year 9 months ago
#3746
And again.
