Automation to turn the SmartRemote screen off when charging
stanger89's Avatar
Re: Automation to turn the SmartRemote screen off when charging
#1770
Haha, sorry, I fixed it.  I'd copied the name originally, but it wanted to insert it as a link, so I tried to type it out, but clearly didn't do it right.  And unfortunately this forum software doesn't let you see the thread when you're creating a post :(
The following user(s) said Thank You: CrabbyPatties
#1771
It turns out it does let you see the thread but it's very well disguised. Along to the right of the submit and cancel buttons when you're creating a reply is an 'X' in a box. Clicking on that reveals the thread. Why an 'X' when that usually means 'close'? Who knows.
stanger89's Avatar
#1776
I never would have thought to try that, thanks!
bitzerjd's Avatar
#1778
Hmmmm,
I cannot get this to work.  I can send a command via AndroidTV to the device (I just turned off the power).  The device is named remote0  and it's ID is 14
The two commands are like this:
{{smartremote_charging_<remote0>}} = true
Macro|
AV|14~SendKey~SLEEP!
It seems the conditions are never met...so nothing in the log.
#1780
Hmmmm,
Macro|
Should you be having <> around "remote0"?
CrabbyPatties's Avatar
#1781
Hmmmm,
Macro|
Attached are screenshots showing how it is setup for me and it works (obv different ids and name for the remote) -
I got rid of the final '!' if that makes a difference - doesn't the '!' separate two separate commands - but it is not required here as there is no command which follows it.
Have you tried testing it by just sending the command straight from the dashboard (weird wizards hat top right) - also see screenshot attached.
