- Thank you received: 3
Function Keys
- bitzerjd
2 years 4 months ago #1831
by bitzerjd
Function Keys was created by bitzerjd
Is there a trick in using the Function Keys (F1...)? I've put in a valid command and it doesn't register on the server. It's the same code that's in a button so I know the code works. I simply want the F2 command to turn on a light (short press) and off (long press).
- Nillaz
- Thank you received: 36
2 years 4 months ago #1832
by Nillaz
Replied by Nillaz on topic Function Keys
What is the command you have assigned to F2?Is there a trick in using the Function Keys (F1...)? I've put in a valid command and it doesn't register on the server. It's the same code that's in a button so I know the code works. I simply want the F2 command to turn on a light (short press) and off (long press).
- bitzerjd
2 years 4 months ago #1833
by bitzerjd
Replied by bitzerjd on topic Function Keys
I tried two codes:
Macro|chair lamp on
and
Lighting|48~On
When I press the button, nothing is recorded on the server. Both commands work fine on other buttons.
Macro|chair lamp on
and
Lighting|48~On
- Nillaz
2 years 4 months ago #1834
by Nillaz
Hmm. Is the soft button that works in the same scene as the hard button you assigned the command to?
- bitzerjd
2 years 4 months ago #1835
by bitzerjd
No, I simply want to control the Home Theater lights by these three buttons. The commands work on other hard buttons, just not these. No errors on the server, the command is not being sent.
- Nillaz
2 years 4 months ago #1837
by Nillaz
Gotcha. I thought maybe you had assigned the commands to a specific scene instead of globally in Project Properites. If it works on some keys but not others within the same scene I'm totally at a loss.
Time to create page: 0.171 seconds
