I am not up fully on Linux permissions, but usually the permissions to access files and directories are set on the host system. The host system also specifies what files and directories external systems can access.
So you might need to set those permissions on the Allonis server. I believe the Linux command is "CHMOD". Note that the Allonis directory that the smart remote's projects are in might also need to be set to allow files to be created, in addition to being edited.
Also, the server usually sets external permissions based on the remote system's user id specified when connecting. Be sure to use the user id when mapping that allows the proper access. I had to use the default user id that Allonis set when they set up the PI (I did not want to bother figuring out other ways to set that user id).
Last edit: 5 months 3 weeks ago by
aa6vh.
