I also have the AV10. I think I used the 7007 receiver from the dropdown, but I don't think it really matters. Not much has changed with Marantz/Denon IP control over the years.
I did need to use a few custom command since I added aux inputs via some button pushes on the front display. The ~test~COMMAND feature comes in handy to do anything that isn't included in the integration. This is my command to select the AUX4 input:
AV|30~test~SIAUX4!
The test command can be used to do any IP command you need. Denon does a much better job publishing their control protocol. I've attached a copy. If you need a command that isn't in the integration, just use the test command and put in the correct string like I showed above.
The following user(s) said Thank You:
cjisble
