HA Control of myServer
Re: HA Control of myServer
10 months 4 days ago - 10 months 4 days ago
#4648
@bitzerjd, you don't want to define each command in your config.yaml. Do it like I showed you with the {{ command }} syntax so that you can pass in the correct command to run each time you run the shell_command action.
Last edit: 10 months 4 days ago by bowlingbeeg.
#4649
bowlingbeeg, Your solution is almost identical to mine (by setting your request parameters into variables then making the HTTP request), except using CURL instead of a RESTFUL request. I am not all that familiar with HA, so I was wondering which is the better way to make HTTP requests in Home Assistant, and why?
I don't think it matter one way or the other.  curl is just a standard linux command line tool that is used for this sort of thing.  The HA rest stuff will work just fine for this.
#4650
Sorry, I don't follow what you are saying. When I try to create a script my screen and options are totally different. I'm fine leaving things where they are right now. My head is starting to hurt working through these hurdles... Thanks for the help, it's greatly appreciated.
Time to create page: 0.355 seconds
