HA Control of myServer
10 months 6 days ago
#4634
I'm making my Christmas list and figured I would ask again...
It would be freaking awesome if you could send commands from HA to myServer.  I have added State indications on my light buttons on my SmartRemote.  If the light is on, the label says "ON" and in some cases changes color.  If I only control the light via Allonis, it's great, everything stays in sync.  The problem is when the light is turned on manually or by a HA automation and the state doesn't match anymore.
I could easily add the automations in HA to update the system variables in my myServer...if the HA to myServer integration existed.
If you could kick off myServer Macros, voice control would be super easy!
I would imagine that having a myServer integration available for HA would be a great selling point.
I've been kind of good this year, maybe Santa has some elves that could cobble something together.
Happy Holidays!
Re: HA Control of myServer
10 months 6 days ago - 10 months 6 days ago
#4635
You can send commands from HA to myServer, just use the API
http://192.168.x.y/api/docommand?command="fill in your command"
Last edit: 10 months 6 days ago by bowlingbeeg.
10 months 5 days ago
#4636
Do you mean through the REST interface? I've tried that in the past and could never get it working.
#4637
I would use the shell command and use curl. I'm not sure if the REST integration would work or not, it might.
www.home-assistant.io/integrations/shell_command/
#4638
I am by far no expert on Home Assistant, I am still trying to figure it out. But I did manage to send commands to my Homeseer4 server. You could do the same thing with the proper changes to address Allonis instead (using the "DoCommand" as described).
Here are my yaml entries for Homeseer (if that helps):
rest_command:
  runevent:
    url: "http://192.168.0.79/JSON?request=runevent&groupname={{ states('input_text.group') }}&name={{ states('input_text.event') }}"
  setdevicelabel:
    url: "http://192.168.0.79/JSON?request=controldevicebylabel&ref={{ states('input_text.devid') }}&label={{ states('input_text.devval') }}"
input_text:
  group:
  event:
  devid:
  devval:
A Sample of one of my Automation's steps:
Then do
Input text 'Set' on DeviceId
Input text 'Set' on DeviceValue
RESTful Command 'rest_command.setdevicelabel'
To send to Allonis, the http request url would be changed to the following, with the macro name setting added to the input_text:
allonis:
http://192.168.0.81/api/docommand?command={{ states('input_text.macro') }}
Someday I might actually try this with Allonis.
#4639
I tried this approach but am struggling how to add them to an automation without manual YAML editing. It would be nice to have a formal Integration, where the components on the myServer were available within HA.
