Cannot add device
Re: Cannot add device
#1209
The last two source commands worked.
​​​​​​It did take two HDMI2 commands for it to change, but only one HDMI1 command.
#1210
Ok, I found on the Interwebs that the projector needs a super secret handshake. You must first send a PJREQ and if it gives you permission then you can send a real command. The driver is now sending the handshake sequence.
#1211
Thank you Dave.
The power off command works perfectly as well.
#1215
While you're in making changes can you add the password that's required on all of the newer JVC projectors? Pretty please ;)
#1250
Saw someone logged in and did some more work with the JVC driver and transferred some files.
May I ask what you were up to ?
#1253
I was refining the driver to finish making changes.
The driver has been updated and it will now track power state. It will also support sending a password if the projector requires it. The AddProjector command now supports an optional password parameter. If you projector does not need a password leave it blank.
Finally the command builder overlay exposes a side panel so that you can directly test command and control of the projector.
The following user(s) said Thank You: bowlingbeeg, Fattykidd
