I see that a new Vizio TV driver was released but I'm still having issues changing the inputs. When I select the Source command, I see the full command listed but then when I select the TV, the command seems to get truncated to not allow the last part. I also tried entering an input at the end of the command manually, like so: AV|2~Source~HDMI3
Is this something that is broken or maybe Vizio doesn't fully support this?
Here are some screen shots of what I'm seeing.
