I just read the support doc, and I was confused by this prerequisite:
This is copied directly from the documentation you linked to.Not fully understanding your question.
HomeAssistant is not needed at all.
But, if you have a HomeAssistant system already, myServer can integrate to it for use with SmartRemote, myServer's more advanced user interface tools, additional drivers, etc.
There is a myServer IRUSB driver within native myServer so no need for HomeAssistant.
Ah, got it. That would be confusing. Doc was updated to say "myServer" is the prerequisite. No need for HomeAssistant for this feature.This is copied directly from the documentation you linked to.Not fully understanding your question.
Pre-requisites:
- AndroidTV integration already setup and in home assistant
- irUSB and companion app setup/installed on Nvidia Shield (should work on other ATV devices, but not tested)
