myServer 6 - SmartRemote Template, license units misreporting, driver page blank
#196
Following the youtube video, the smartremote template looks like it downloads, installs, and the server reboots, but when it comes back up it shows that it is uninstalled.  Tried installing several times but still does not show as installed.
When installing software for various A/V equipment, nothing is showing up under the Drivers page.  It's basically blank except the menu.
Also, on the main page, license units says 175 after registering instead of 300 like it should.
Re: myServer 6 - SmartRemote Template, license units misreporting, driver page blank
#198
I am also having a problem getting the template to install, and I have a feeling I'm pretty much dead in the water until I can get it resolved. I'm not sure where to go from here.
OTOH I was able to install the drivers for a bunch of things like HEOS, AndroidTV, etc so I at least know that I'm capable of downloading items from the Software Updates page.
stanger89's Avatar
#200
I got a number of drivers installed, and they scanned and found devices, but then I updated to 6.7.3203.41994, and now my drivers page shows blank.
#205
I also updated to 41994 and my drivers are still visible. It also now shows that the smartremote template is installed, and if I'm interpreting the icon in the upper right of the remote correctly it is connected to the server. Other than that I'm still stuck. If I go under Management/Templates it doesn't show the smartremote template (though it does show the moonlight template for tablets and phones even though they are not listed in the Software Update page as being installed?!?). myDesigner also doesn't seem be able to pull up the project files as the left pane is still blank.
I followed along with the youtube tutorial but nothing has gone as expected. I've been looking forward to this for quite awhile so I'm kind of bummed.
#207
I am guessing that you saw 300 units when in 30 day trial mode.
Did you recently request Activation?
If so, then on next reboot, the system was registered with the 175 license units that were purchased (that are now permanent).
#208
We are working on putting versioning in the templates...If you have a keyboard / mouse and HDMI monitor, you can to go to
/home/allonis/applications/myServer/wwwroot
to see if the template really is there but just not currently showing in the myServer template view.
Update to latest myServer and restart and downloaded templates should now display in Dashboard / Management / Templates.
Time to create page: 0.260 seconds
