Change your python script to output the result as json? All you'd have to do is split on the commas in the string and print out {'res1": "I24", "res2": "0", ...} instead.Yeah I kind of figured. I was hoping it would magically split the comma separated values into variables.
I have the lumagen connected to the PI using the usb cable that came with the lumagen. The lumagen has a usb->serial connection built into the unit. So I wrote a python script that will take a command as input send it to the lumagen over the /dev/ttyUSB0 and then it will print out the result. I had tried to use the serial driver but I couldn't ever get that to work and never got a response from Allonis so I'm not sure why that didn't work( allonis.com/forum/generic-serial-driver/...-serial-driver-error ).
