Refreshing the page doesn't re-implement the offset. The modified offset value is still stored in the button properties but the icon itself remains centered.That will happen while the button is in edit mode. When you save the offset will revert to 0 but if you refresh the page the offset should come back. This is because the button needs a full rebuild. Can you confirm that the offset is maintained after a page refresh? It's an annoyance I've been meaning to fix for a while. It will get done.
Some further info: The vertical offset is maintained when just adding a static icon to a button. The problem arises when you are using button states to toggle between different icons. When doing this the icon will always revert to the center of the button regardless of the vertical offset. I found this because I'm trying to have the button switch between two different power plug icons to differentiate the on/off state of some zwave plugs I've incorporated.That will happen while the button is in edit mode. When you save the offset will revert to 0 but if you refresh the page the offset should come back. This is because the button needs a full rebuild. Can you confirm that the offset is maintained after a page refresh? It's an annoyance I've been meaning to fix for a while. It will get done.
