Devices not Appearing in Sources & Apps
Gerald Graef's Avatar Topic Author
2 years 1 day ago
#3249
I started setting up MyServer 6 a couple of months ago but wasn't able to do the SmartRemote setup until now. Alas, I suspect I did something wrong because only one device shows under Sources&Apps (e.g Roku does not show).  The "unknown" room was missing so as a long shot I tried adding it but still doesn't work. Any thoughts on what I can try to get devices showing up?  The Roku device type is set to Roku.
Thanks!
Gerry
Re: Devices not Appearing in Sources & Apps
2 years 1 day ago
#3254
Hi Gerry,
Please ensure you are following the documentation carefully step for step, marking off each step accomplished without jumping steps.
Critical to avoid issues.
1 year 11 months ago
#3445
David,
Thanks for the response.  The issue was a typo/mis-match curtesy of doing this too late at night...
Follow on quesiton: I have an AVR in my theater but the SmartRemote hard volume buttons are always resolving to change the display volume.  I see the SR is sending a "Volume" command but don't see where a (presumably?) default to use the display volume is over-written.  The "activate.room" macro has the line to override default volume setup as does the "volume.room" macro.  Yet this is the command the server is processing:
AV|{{{{activeroom_{{clientname}}}}_display_id}}~Volume~up from remote
What needs to be set to get the SR to use the AVR (denon in this case) to process volume/mute buttons?
Thanks!
Gerry
#3446
allonis.com/support/documentation?view=category&id=413
See How it Works section at bottom.
If you make the edits and it's not working, post what you edited and the myServer event log on what is processing.
#3462
The onlychange I made was to the "Active-room.theater" macro, and that was to uncomment the following line (and change 0 to 5):
    // The device in the room that controls volume and mute. Uncomment to override default!
    SetVariable|{{activeroom_{{clientname}}}}_avamp_id~5
I have five sets of auto-gen macros created for the theater room: (comments removed for brevity)
active-room.theater
    SetActiveRoom|Theater!
    ActivateRoomDevices|{{activeroom_name_{{clientname}}}}!
    SetVariable|{{activeroom_{{clientname}}}}_avamp_id~5!  << I uncommented this
display.theater
    AV|{{theater_display_id}}~Power~<p1>!
power.theater
    AV|{{theater_avamp_id}}~Power~<p1>!
volume.theater
    AV|{{theater_avamp_id}}~Volume~<p1>~3!
volumemute.theater
For reference:
theater_display_id = 4
theater_avamp_id = 5
The event log shows the Roku being called to change volume:
On a side note, the moonlight screens volume works fine though.
Gerry
