Having "sensor" in the name being identified as type sensor is good thing in my opinion. I was only suggesting that adding a line to the documentation noting this would be helpful. If you are making a change such that a name with "switch" in it will be identified as type switch, should also be noted in the documentation.I thought if it had Sensor in its name that it should be a Sensor. It will be a Remote now.
Any device with a name with Switch in it will be a switch.
