I have tried all of that prior to this post, sorry if it wasn't clear. I am seeing a similar issue to another user on the forums, here is his post
I'm still having issues with adding a fire tv as a device.. I'm not sure if the issue is related to the image this time because it seems to be just with MyServer. ADB is working on the Pi server. ADB Debug is on on the Fire TV stick. I can connect to the the FireTV using the adb command on the terminal from the pi server and it will show up in the devices if I do a terminal command of adb devices. In myserver I can't add a device, none are discoverable, nothing shows up in the list.
When I try to manually AddDevice command in the driver manager for the andriodtv driver, it returns a "Error in MoveNext The input string [depends on what string used] was not in a correct format" In system events. I've deleted the use of that single variable it errors,(for example friendlyname) but then errors on another value (for example Room Name) in the string. is this a related issue to the image or is it something I'm missing in the documentation? Thanks!
Last Edit:7 months 1 week ago by
Mark Stocku
I am seeing the same error in the logs, when trying to add back my smartremote, or the google tv streamer. Futher info I can connect to the google tv streamer via terminal adb commands from another machine.
