Hi,
Does anyone know if it is possible to power a Myserver 6 using a POE splitter? I’m trying to cut down on the amount of power adapters.
I did more research on powering a Raspberry PI 4 over a POE splitter and it looks like, in theory, it should work. It looks like myServer 6 will run on less than 30 watts which is what most POE switches will handle per port.
After, further research I have found a conflict of information.
- On the rewards pages of the Kickstarter event the shelf mount myServer 6 says there is a 12 volt 2a wall wart included.
- On the Allonis products page the shelf mount myServer 6 has a 3.5 amp USB-C Power Supply - wall mount included.
David, please clarify which Power Supply will be shipped with the shelf mount myServer 6?
Any comments are welcome.
Thank you,
Tom
Last edit: 2 years 9 months ago by
Thomas Wheeler. Reason: Additional information added
