SmartRemote and MyServer IP
camens's Avatar Topic Author
9 months 4 weeks ago
#4751
I changed the IP of the MyServer 6 Raspberry PI and moved it to a new VLAN.  Everything is running, but I'm having trouble connecting 2 of my remotes.  The VLAN can see the remotes and both can be successfully pinged.  When the SmartRemote starts up it loads, but then can't find the server due to the new IP, so the top right corner shows the green wifi icon and the green server icon  Then, if I choose the hamburger menu it gives me 3 options.  Configure WIFI, App Settings, and Exit SmartRemote.  I'm assuming the setting for the Server IP is on App Settings, but clicking that button does nothing.  In fact both Configure Wifi and App Settings don't work, although Exit SmartRemote does.  How can I point the remote the correct server IP?  Do I need to uninstall and reinstall?  (And both remotes are having the exact same problem).
Re: SmartRemote and MyServer IP
9 months 3 weeks ago
#4752
I solved this by putting MyServer back to its original IP, connecting the remotes, and then I had access to set them to the new IP.  Once I placed MyServer to its new VLAN and IP, nothing more was really required and the remotes connected.
9 months 3 weeks ago - 9 months 3 weeks ago
#4755
SmartRemote must communicate to myServer's webserver via it's IP address. They must be on the same network (like 192.168.1.100 and SmartRemote on 192.168.1.101). Note that myServer can be on multiple networks at the same time ie: VLAN 10 at 10.1.10.249 is the "control" network that Allonis uses. myServer talks to both.
Last edit: 9 months 3 weeks ago by David Li.
Time to create page: 0.066 seconds
