Sprinkler Relay Questions
Chrisan's Avatar Topic Author
Re: Sprinkler Relay Questions
6 months 5 days ago
#4863
It's the same as SKU  101-70-141.   Discontinued.   Found here.    www.sainsmart.com/products/rj45-tcp-ip-r...ntegrated-8-ch-relay
Thx
6 months 4 days ago
#4864
I'm still not clear on how the Sainsmart driver works and what exactly goes in the Device Address field.   Advice appreciated.  Thx.
5 months 4 weeks ago - 5 months 4 weeks ago
#4867
IPRelays|AddController~Name~Address~Port~Relays~room
That's the Add Device command. Address= IP address, Port = the port you have the relay configured for ie: 3000, Relays = number of relays on the controller ie: 8. Room can be "Equipment"
Do you have the relay working via it's embedded webpage?  That's first step.
Last edit: 5 months 4 weeks ago by David Li.
#4869
The relay controller can be accessed and controlled using a browser by typing in 192.168.10.25/30000.
I did find this in the iMatic documentation."Note:  the "Port" is not really a port number at all.  It is just a custom URL path.  So, the device is always on Port 80 and cannot be changed if you need to Port Forward your firewall for some reason.
I tried IPRelays|AddController~IPRelayController1~192.68.10.25~30000~8~Infrastructure.
The resulting screen looks like the attached - blank device address..  I have tried manually configuring the address 192.168.10.25/30000 or 192.168.10.25:30000 or 192.168.10.25:80 or  http://192.168.10.25:80.  Can't find something that makes MyServer happy.
Thx
5 months 3 weeks ago
#4871
Still can't get this to work.   So exactly what is supposed to go in the device address?  And what format?
Thanks Chris
#4878
Still can't figure this out.   Response to my previous message would be appreciated.   I also tried the iMatic driver with similar results.  Thx.
