Weather Variables Won't Load
Re: Weather Variables Won't Load
1 year 7 months ago
#4113
The cities in the list are what exists.
Use the closest.
Chrisan's Avatar Topic Author
1 year 7 months ago
#4114
I can get West Bloomfield to show up if I type West Boomfield,MI into the zip code/city field. Then hit submit. Then select city shows up. I select West Bloomfield and hit submit. Then nothing. I would assume it would show up in the upper box but nothing there. Please advise if I am doing something wrong or when this gets fixed. Thx
1 year 7 months ago
#4118
Any more suggestions on this ?    I've followed the documentation and still can't get it to work.   There's not much else I can do from my end.
Thx
#4121
This still isn't working. Nothing close to me is working. I can bring up West Bloomfield or Wixom or Farmington and they all are listed but nothing happens when I hit the lower submit button. I can get Detroit but Detroit is NOT at all representative of my weather here in W Bloomfield.
Edit:   I found Pontiac and maybe that can serve as a proxy for West Bloomfield.   I don't know why all the other city names are in there if they can't be used.  And just a note, I couldn't activate Pontiac using the command builder until I restarted myserver
Last edit: 1 year 6 months ago by Chrisan.
1 year 6 months ago
#4122
I am not seeing West Bloomfield in the list.
Edit Detroit. Type West Bloomfield as the name.
Here is West Bloomfield Lat / Lon to add
42.5575° N, 83.3614° W
If that Lat / Lon doesn't have a weather station (likely not) the system will use the closest there is.
And that's as good as can be done.
1 year 6 months ago
#4123
Thanks David. I will try that. Where is this list you referenced? What I am trying is just my zip code - 48322. When I type it in and hit submit the lower box appears and asks for my city. West Bloomfield appears and I select it. Hit submit then nothing. But like I said, I will try what you suggested.
Thx
Time to create page: 0.743 seconds
