Fan automation based on light status?
graydon@gdsamps.com's Avatar Topic Author
#1766
I have a radon mitigation fan running 24/7 but it is annoying when I am in my basement shop.  I decided to build a simple automation to turn it off any time my shop light is on.
The shop light is lighting_38
The shop light status can be read on lighting_38_status
The fan is on a Shellyplug which is lighting_302
I have verified that both the light and the fan can be operated by a lighting command in the command line of Myserver6 and if I look up the status variable I can see it changes when the light status changes.  Also, in my lighting floorplan, the shop goes gray (indicating a light is on) whenever that light is on so I know that Myserver knows how to respond to the status of that light.
I'd add a screenshot of the automation but this forum software is the pits, but that's a different topic.
Under "Automation Rule Conditions" I wrote:
WHEN:
{{Lighting_38_status}}=on
Under "Automation Rule" Actions I wrote:
Macro|
Lighting|302~off!
WebCmd|all~Toast|warning~Radon Fan Notification~The Shop light is {{lighting_38_status}}~10000!
Any ideas what is wrong with my syntax?  BTW, I also wrote a second automation to turn the fan back on whenever that light is turned off.  I'm sure it could all be done in one automation but I'm not a programmer.  One thing at a time while I'm learning. :-)
Thanks,
Last edit: 2 years 8 months ago by graydon@gdsamps.com.
Re: Fan automation based on light status?
See this example...the DelVariable gets rid of the "old" message after it has displayed (a reset)
Macro|
WebCmd|all~Toast|warning~SmartRemote8~SmartRemote8 is on charge. {{smartremote_battery_smartremote8}}%~5000!
DelVariable|message_1
Is the automation event firing? What's in the log? What's it getting done once fired vs, not getting done? Do you see the Toast message?
Nothing happens at all.
I just checked the log. I see there is an error.
"ERROR · Automations.LoadRules - Cannot parse [AND:{{Lighting_38_status}}=on] in rule radon off "
This is what is in the Automation Rule Conditions:
WHEN:
WHEN:
did you copy / paste that variable name?  ie: is L or l?
Good catch.  The correct spelling for that variable is with a lower case "l" as in "lighting_38_status"
I still get the same error though so that was not the only problem.
I deleted the colon after "WHEN" and that eliminated the error message but it still doesn't work.
The parser is a bit picky. It needs white space around the operators
change
WHEN:
to
WHEN:
{{lighting_38_status}} = on
