CrabbyPatties's Avatar
#1503
This hasn't fixed the overrun issue.  Behaviour is exactly the same as prior.  I updated to latest drivers, latest template, updated project etc and no difference.  To made absolutely sure, I also checked it with the default smart-remote template and that also has the same behaviour.
#1535
my only option is to remote in and look at your log files to see if i can understand what it is doing.
#1541
I was going to send the logs over re the hard key overflow, but now I have a more serious problem.  The server will no longer connect to the Harmony Hub.  Is this due to the 'keep alive' issue that was changed recently?
 11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Reconnecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Disposing11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Nulling11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Creating11/03/2024 17:23:48.23 · DEBUG · Harmony.ConnectAsync - Connecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · ERROR · Harmony.ConnectAsync - Error in ConnectAsync - Unrecoverable stream error: resource-constraint11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Reconnecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Closing11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Disposing11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Nulling11/03/2024 17:23:48.23 · DEBUG · Harmony.ReconnectToHub - Creating11/03/2024 17:23:48.23 · DEBUG · Harmony.ConnectAsync - Connecting to Hub Hub at 192.168.68.56 at 192.168.68.5611/03/2024 17:23:48.23 · ERROR · Harmony.ConnectAsync - Error in ConnectAsync - Unrecoverable stream error: resource-constraint
Last edit: 2 years 7 months ago by CrabbyPatties.
#1542
Please provide your TeamViewer info. Dave will need to log into the system directly to diagnose.
Thanx
David
#1544
Emailed it to you, thanks
#1556
your system isn't online to TeamViewer.
