Re: Anthem Driver
#2185
I have been tied up with Harmony Driver changes. I'm am looking in this right now.
Anthem driver is update. 0 to 100 should now send -90 to 10.
bitzerjd's Avatar
Re: Anthem Driver
#2188
Thanks!!!!
Works great...just tested it.
Last edit: 2 years 6 months ago by bitzerjd.
Mark Guebert's Avatar
Re: Anthem Driver
#2389
I have a AVM60 and the driver is working for volume, mute, and source select.
However I would like to program in the buttons needed for OSD. Looking through the docs, I thought the test command would work with Zsimyyyy where yyyy is the simulated IR code. However it doesn't seem to work
Simulated IR Command values for ZxSIMyyyy (use 0 to fill in blanks Ex: Key 1 = 0001) yyyyMain Zone
IR Key
0Key 01Key 12Key 23Key 34Key 45Key 56Key 67Key 78Key 89Key 910Power On11Power Off12Setup13Input14Mode15Dim16Level17Info18Up19Down20Left21Right22Select23Page Up24Page Down25Volume Up26Volume Down27Mute Toggle28Last29Tone30Bass31Treble32Lip Sync33Balance34Dynamics35Clear36Preset  Simulated IR Command values yyyyZone 2 IR Key10Zone 2 On11Zone 2 Off13Zone 2 Input23Zone 2 Next Preset24Zone 2 Previous Preset25Zone 2 Volume Up26Zone 2 Volume Down27Zone 2 Mute Toggle
Last edit: 2 years 5 months ago by Mark Guebert. Reason: Formatting
Re: Anthem Driver
#2391
Are to sending Test~ZxSIM0000?  The little x needs to be a 1 for Zone 1 or 2 for Zone 2  ---  Test!Z1SIM0010 power on
Are you seeing any RX response from the Anthem?
bitzerjd's Avatar
Re: Anthem Driver
#2442
IRCmd usage
I'm trying to use the Anthem "Level" command by executing this from the Command Builder...."AV|7~IRCmd~Level".  When I issue the command, nothing happens.  The Anthem integration works fine, Vol, Source, etc.  I cannot get any of the IRCmd commands to work.
What an I missing?
Re: Anthem Driver
#2443
Pilot error on my part. Driver has been updated.
The following user(s) said Thank You: Mark Guebert
