Slow menu navigation?
glitchhound's Avatar Topic Author
4 days 23 hours ago - 4 days 23 hours ago
#5176
Hi there,
I'm using the smart remote with my Shield TV Pro, with the arrows mapped to UP/DOWN/LEFT/RIGHT/ENTER on the v2 driver (I used DPAD_ commands on the v1 driver successfully, but had to change to these for v2. The rest of this post applies to both v1 and v2). I've noticed that menuing is much slower than with the native remote or even how I remember my Harmony remote working (it's slowly failing and that happens to be one of the functions it's lost, so I can't be certain).
It seems like the remote and/or myServer is waiting for a full round-trip to complete. When I press right 3x, instead of moving right 3x in quick succession, it moves right once, then again, then again, with equal delay between each press as if they were all the first. With the Shield's native remote, it seems more like the requests are processed in parallel, so there is no accumulating delay as I input more commands.
Is this something that I should just learn to accept, or is there something which can be done to improve perceived performance?
Last edit: 4 days 23 hours ago by glitchhound.
Re: Slow menu navigation?
3 days 23 hours ago
#5177
It seems to be a very common problem, and when I googled it when it first came up I found people using other ADB based remote control of Android devices (other than myServer that is) had similar problems. I lashed up a network controlled pretend HID keyboard that seems to work for me. Or I believe there is a commercial product called a Videostorm IRUSB that fulfils the same function. Of course it would be better still to keep it native within myServer.
allonis.com/forum/androidtv-driver/568-u...after-os-update#4956
3 days 23 hours ago
#5178
1 day 9 hours ago
#5181
Ensure your system is using the later Android Driver.
I use this every day and find the response likity split.
4 hours 42 minutes ago
#5183
But are you using it with the Shield TV Pro?  I am having a terrible time with the new driver on this device.
