SM 10 Buttons White icons
Introducing iPort Surface mounts
We love these iPad mounts as their fit / finish is second to none.  Plus, they have hard buttons that send myServer commands for common functions like Volume, Channel, Home Page, Set light levels, etc.  Any command can be mapped to any button in the new iPort myServer Driver.  As a Thank You for purchasing from Allonis, the myServer Control Family license is included with the purchase of the iPort Surface mount, if you haven't already purchased that.  Your iPad slides right in and can display your myServer webpages with ease.
The iPort Surface with buttons requires an ethernet (Cat5/6) cable with POE (Power over Ethernet).  The iPort must be on the same network as myServer.
We recommend that this mount is placed in high traffic areas of your home.  The Foyer, the Kitchen and the Hallway make great sense.  Don't forget that you can use myPhotos to setup a slideshow when you aren't using the iPad as a control system.  Reflect on your kid's pictures and some great vacation memories as you walk by.
Ok, they are a bit expensive...compared to cheaper looking frames....but if you add in the price of an iPad, still way cheaper than the competitions proprietary (and slower) touchscreens!
Versions Available
SM 6 Buttons Silver icons 1
SM 10 Buttons Black icons
Surface Mount with Buttons
for iPad mini 4
6 button model [joocart product_id=133]    10 button model [joocart product_id=134]
Available in Black, Silver or White finishes.
SM 10 Buttons Silver icons
for iPad Air 1 | 2 | Pro 9.7"
6 button model [joocart product_id=135]    10 button model [joocart product_id=136]
SM 6 Buttons White icons
for iPad Pro 12.9"
6 button model [joocart product_id=137]    10 button model [joocart product_id=138]
