Video Walls are for Sport Bars, Lounges and for Marketing displays
It can be very challenging for non-technical users to control these advanced display systems. myServer can be used to select which content source to play across the video displays and the combination of displays in an intuitive way.
(Rendering - bezel gaps are dependent on display model used)
Watch the Big Game across all of the displays
Choose which grouping of monitor(s) to display your chosen source from our easy to use touchscreen interface.
Conventional TV compared to Video Wall small bezel Displays:
Regular TV display
Regular TV display
Narrow bezel video wall display
Allonis available display solutions:
Examples:
images/products/55LV35W4C_2x2wall.jpg
LG 55" shown above
LG 55" 2X2 - $23,493 with wall mounts. Does not include video matrix processor. 500nit, 24x7 service.
47.8” x 26.9” x 3.5” each display. 3.5mm bezel to bezel. 95.6" x 53.8" total
LG 49" 2X2 - $15,394 with wall mounts. Does not include video matrix processor. 450nit, 24x7 service.
42.4” x 24” x 3.5” each display. 2.3mm (Left / Top), 1.2mm (Right / Bottom). 84.8" x 48" total
Samsung 55" 2X2 - $15,722 Does not include video matrix processor. 450nit.
48.1" x 27.3" each display. 11mm Bezel to bezel. 96.2" x 54.6" total
Video Matrix 4x4 processor:
Most commonly, a video wall is supported via the video distribution matrix. HDBaseT and Video Over IP technologies both have models that support video wall processing. Consult with Allonis on the type of matrix needed.
If the video wall is to be supported without a video matrix:
AVPro DVI-ProWall-4X WUXGA (1920x1200) matrix processor (one input to four displays) - $2,999
CELabs DVPS44 $3,570 (four inputs to four displays) (does not include cabling)
LG 55" shown above
LG 55" 3X3 - $52,859 with wall mounts. Does not include video matrix processor. 500nit, 24x7 service.
47.8” x 26.9” x 3.5” each display. 3.5mm bezel to bezel 143.4" x 80.7" total
LG 49" 3X3 - $34,524 with wall mounts. Does not include video matrix processor. 450nit, 24x7 service.
42.4” x 24” x 3.5” each display. 2.3mm (Left / Top), 1.2mm (Right / Bottom). 127.2" x 72" total
Samsung 55" 3X3 - $35,397 with wall mounts. Does not include video matrix processor. 450nit.
48.1" x 27.3" each display. 11mm Bezel to bezel. 144.3" x 81.9" total
MXWall 8x8 wall matrix processor - $11,999
AVPro DVI-ProWall-9X 4K (3840x2160) (2 inputs) matrix processor. Uses PIP - $8,495
Install 2x2 video wall on flat drywall w/ studs - approx. $2000
Install 3x3 video wall on flat drywall w/ studs - approx. $3000
Installation includes calibration. Wire and Wiring labor additional and will be quoted to job specifics
Video walls should be configured and wired:
For a 2x2:
