Allonis provides a simple, consumer grade Wifi Router configured to run simple systems for Trade show demo booths, demonstration systems, small homes, etc.
Here is how it is setup:
Plug in Netgear Router power supply into UPS and power this up first.
Ethernet Connection of the system:
- Optional Internet connected LAN (for Allonis to remotely connect to the system) connects to WAN connector (yellow) of Netgear Router.
- LAN connections of Netgear then plug into devices and / or unmanaged ethernet network switch.
- Connect each device into the ethernet network switch ports.
Wifi connection to the system
To control the system, you can connect to the Netgear Router via Wifi: Allonis / allonis123
Allonis remote connection to the system
The WAN port of the Netgear Router can be connected to an Internet accesible network. The router will get it's WAN IP address from the Internet network's DHCP server. The myServer controller has TeamViewer running on it that will then be accessible by Allonis for programming or troubleshooting assistance. No external dedicated public IP address is required on the WAN.
System configuration
Netgear R6260 router) IP 192.168.2.1 admin / Allonis123 Wifi: Allonis / allonis123
myServer 6) IP: 192.168.2.10/dashboard 192.168.2.10/projectname
settings / safari / request desktop website / all website = off
Player1) IP: 192.168.2.11
Player2) IP: 192.168.2.12
Player3) IP: 192.168.2.13
Player4) IP: 192.168.2.14
Cloud9) IP: 192.168.2.8
Boot Order
Boot the Wifi Router first. Let it fully get online. It is the DHCP server for all other devices.
Connect Laptop Wifi to WifiRouter (Allonis network / Allonis123)
Boot myServer 6 controller
You can then start the show via the Laptop browser: http://192.168.2.10/projectname
Example network ranges
interface=eth1
dhcp-range=192.168.0.200,192.
# myServer Clients 192.168.0.2 - 9
dhcp-host=58:82:a8:90:fd:cf,
# Global Cache/IP2IR IP2IR Devices 192.168.0.10-20
dhcp-host=00:0C:1E:05:7B:0E,
# Video Matrix Devices 192.168.0.21-30
# Audio Matrix Devices (DBX default node 30) 192.168.0.31-40
# TV (IP controlled) 192.168.0.41-120
# Lighting Controllers 192.168.0.121-130
DirecTV 192.168.0.13
Advanced networking controls:
ping 192.168.1.100
sudo nmap 192.168.1.0/24
adb devices
adb connect 192.168.1.125
sudo nmap -p- 192.168.1.125 Detects ports open
adb disconnect 192.168.1.125
ifconfig
