How to issue curl commands within myServer for automation?
8 months 1 week ago
#4763
Hey guys I have a Tetratune video processor in my home theater and up to this point I've been controlling this through it's built in web server but I would very much like to enable some automation through myServer. It's a niche device that's only been available for a few months so there's obviously no native driver available in myServer, but today Videworks (the manufacturer) has implemented a public API for automation along with the necessary documentation. It uses Curl for this.
For example I'd like to be able to be able to enable/disable the video processor on the fly from my remote. The commands to do so are:
curl -X POST 192.168.1.xxx/colour_tuner/enable/true -d '{}'
curl -X POST 192.168.1.xxx/colour_tuner/enable/false -d '{}
I know absolutely nothing about curl, but from what I gather myServer has the capability of issuing these types of commands. Can anyone tell me how I would add this to a myServer macro? I assume there is some additional syntax that is required beyond me just pasting these exact lines into my command sequences.
Since I don't know what I don't know if I'm not providing enough info here I can certainly provide the API documentation if it would be helpful. Any insight would be greatly appreciated. Thanks in advance!
Re: How to issue curl commands within myServer for automation?
8 months 1 week ago - 8 months 1 week ago
#4764
You would use PostURL. Something like:
PostURL|http://192.168.1.xxx/colour_tuner/enable/true~{}
Last edit: 8 months 1 week ago by andrew.
8 months 1 week ago
#4765
Just to elaborate, I created a Macro using that Allonis statement with Macro replacement parameters specified.
For example (using a "Get" HTTP statement instead of a "Post"):
Macro hs_run_event (which initiates a Homeseer event):
GetUrl|http://192.168.0.80/JSON?request=runevent&groupname=&name=
And when I want to invoke it:
hs_run_event|TheGroupName~TheEventName
-- the reulting http command that is actually sent to Homeseer is:
http://192.168.0.80/JSON?request=runevent&groupname=TheGroupName&name=TheEventName
8 months 1 week ago
#4766
I think the editor/forum software ate your p1 and p2 parameter tags.
GetUrl|http://192.168.0.80/JSON?request=runevent&groupname=<p1>&name=<p2>
8 months 6 days ago
#4768
Just tested and POSTURL let's me manually enable/disable the various toggles in the VP and switch between different 3D LUT slots. This is WAY better than having to juggle between the remote and a web browser on my phone.
Now I need to figure out how to query the VP for the attributes of whatever content is currently playing and add them as variables in myServer. I suspect this is going to be a bit more complicated lol
Thanks for putting me on the right path you guys are awesome!
8 months 6 days ago
#4769
I use RunParseResults to run a local shell script on the server and parse the returned JSON output into myServer variables.
RunParseResults|/home/allonis/scripts/startdowntime.sh~~mydowntimestart!
Time to create page: 0.310 seconds
