jrfuda
My DVDLobby HomeSeer Script - UPDATED
Thu Jan 20, 2005 2:35 pm
As some of y'all may have been following. I've been perfecting my method of getting DVDLobby and a hybrid CX777ES/HDD system to work seamlessly. Well, after some advice from you folks, purusing MSDN, and lookin at other HS scripts, I came up with this combination of MLServecmds and HS script. This script will launch a trailer from the HTPC based upon the movie's soundtrack, and then lanuch the movie from the appropriate source (777 or HDD) or switch the inputs for an offline movie (DVD or VCR).
Here's my default play movie command:
MLServeCmd.Macro|MLHSPLugin|HS_Speak:Please standby!SetVariable|CHANGERLOC~<<CHANGERLOCATION>>!SetVariable|FILENAME~<<FILE>>!SetVariable|TITLE~<<TITLE>>!SetVariable|FIXEDTITLE~<<FIXEDTITLE>>!SetVariable|COLLNUMBER~<<COLLECTIONNUMBER>>!SetVariable|CHANGER~<<CHANGERNUMBER>>!SetVariable|SOUNDTRACK~<<CUSTOM1>>!SetVariable|PREFIX~<<CUSTOM2>>!MLPause|1!MLHSPLugin|HS_SetDeviceString:T2~{{TITLE}}!MLHSPLugin|HS_SetDeviceString:T3~{{FIXEDTITLE}}!MLHSPLugin|HS_SetDeviceString:T4~{{CHANGERLOC}}!MLHSPLugin|HS_SetDeviceString:T5~{{FILENAME}}!MLHSPLugin|HS_SetDeviceString:T6~{{COLLNUMBER}}!MLHSPLugin|HS_SetDeviceString:T7~{{CHANGER}}!MLHSPLugin|HS_SetDeviceString:T8~{{PREFIX}}!MLHSPLugin|HS_SetDeviceString:T9~{{SOUNDTRACK}}!MLPause|3!MLHSPlugin|HS_Run:DVDLobby.txt
And here is my HS script (I know I could havestreamliined it a bit by reusing code, but I don't know how to do that yet) I now have all the required trailers (or suitable substitutions) so I have the timings for each playlist (as reported in ZoomPlayer's playlist dialog) down, plus I've added 5 seconds to each one for opening/closing/transition/etc. Here is the code:
sub main() Dim TITLE Dim FIXEDTITLE Dim CHANGERLOC Dim FILENAME Dim COLLNUMBER Dim CHANGER Dim PREFIX Dim SOUNDTRACK Dim PLAYER Dim TRAILERLENGTH Dim LAUNCHPAUSE Dim TRAILERCOMMAND Dim MOVIECOMMAND Dim ASPECT 'future use to set AR on Zoomplayer for HDD movies (a fix for 4:3 material) /AR:4=16:9, /AR:3=4:3 use CUSTOM3 in DVDL, currently all HDD movies ARE 4:3, so I'll just include /AR:3 in MOVIECOMMAND '***Give MLServer time to populate devices*** hs.WaitSecs 1 '***Get Device Strings*** TITLE=hs.DeviceString("T2") FIXEDTITLE=hs.DeviceString("T3") CHANGERLOC=hs.DeviceString("T4") FILENAME=hs.DeviceString("T5") COLLNUMBER=hs.DeviceString("T6") CHANGER=hs.DeviceString("T7") PREFIX=hs.DeviceString("T8") SOUNDTRACK=hs.DeviceString("T9") '***Close uneccessary programs and minimize everything*** hs.plugin("MLHSPlugin").MLServeCMD "MLWindowFunctions|Media Center~CLOSE" 'just in case mediacenter is running hs.plugin("MLHSPlugin").MLServeCMD "MLZoomPlayer|EXIT" 'just in case Zoom is already playing something (like a trivia playlist) hs.Launch "C:\show desktop.scf" 'minimize everything on the desktop '***Determine method of playback*** if PREFIX="C" then PLAYER = "D V D Changer" if PREFIX="H" then PLAYER = "H T P C" if PREFIX="O" then PLAYER = "Single D V D Player" if PREFIX="V" then PLAYER= "V C R" '***Announce movie and method of playback*** Set fs = hs.CreateStringClass fs.Add "Launching " fs.Add FIXEDTITLE fs.Add " from the " fs.Add PLAYER system.speak fs.Value fs.Reset '***Determine Trailer Length*** if SOUNDTRACK="DD" then TRAILERLENGTH = "33" 'Generic DD (too short) if SOUNDTRACK="DDEX" then TRAILERLENGTH = "50" 'Generic DDEX if SOUNDTRACK="DTS" then TRAILERLENGTH = "105" 'Generic DTS (too long) if SOUNDTRACK="DTSEX" then TRAILERLENGTH = "105" 'Still need a trailer (too long) if SOUNDTRACK="DPL" then TRAILERLENGTH = "33" 'Generic DPL, will add something for length (maybe THX) (too short) if SOUNDTRACK="MONO" then TRAILERLENGTH = "81" 'Flying Cubes if SOUNDTRACK="STEREO" then TRAILERLENGTH = "76" 'DDStereo Train if SOUNDTRACK="DDCANYON" then TRAILERLENGTH = "64" 'DD for some action/adventure-type movies if SOUNDTRACK="DDCITY" then TRAILERLENGTH = "60" 'DD for comedy, crime if SOUNDTRACK="DDEGYPT" then TRAILERLENGTH = "63" 'DD for some action/adventure movies if SOUNDTRACK="DDSF" then TRAILERLENGTH = "63" 'DD for space-based movies (DD Aurora Trailer) if SOUNDTRACK="DDDRAMA" then TRAILERLENGTH = "60" 'DD for Dramas (DD Rain Trailer) if SOUNDTRACK="DDSTARWARS" then TRAILERLENGTH = "80" 'DD for Star Wars series (SWTHX trailer + DD Enlighten Trailer) if SOUNDTRACK="DDANIM" then TRAILERLENGTH = "78" 'For animated features '***Determine LAUNCHPAUSE*** LAUNCHPAUSE = cstr(TRAILERLENGTH)- 27 '***Determine TRAILERCOMMAND*** TRAILERCOMMAND = """C:\Program Files\Zoom Player\zplayer.exe""," & " ""/ADD:G:\Video\PLAYLISTS\" &cstr(SOUNDTRACK) &".ZPL /AR:4 /SPEAKER:0 /LOCKFS /VOL:90 /DVD /PLAY /MOUSEOFF /Q""" '***Determine MOVIECOMMAND*** MOVIECOMMAND = """C:\Program Files\Zoom Player\zplayer.exe""," & " ""/ADD:G:\Video\" &cstr(FIXEDTITLE) &" /AR:3 /SPEAKER:0 /LOCKFS /VOL:90 /DVD /PLAY /MOUSEOFF /Q""" '***Determine ASPECT*** '***Launch Movie from Changer*** if PREFIX="C" then hs.WriteLog "DVDL", "Launching from DVD Changer" hs.plugin("MLHSPlugin").MLServeCMD "MLServeCmd.MLCX777ES|PowerOn" 'turn-on CX777ES hs.WriteLog "DVDL", "CX777ES Powered-on" hs.WriteLog "DVDL", "Switching components for HTPC trailers" hs.SendIR "TV_Panasonic,Volume_Down,,TV_Panasonic,Mute,,TV_Panasonic,Channel_Up,,,Receiver_Yamaha,Power,TV_Panasonic,RGB_In,,,Receiver_Yamaha,MD-in,TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,Volume_Down" 'sets components for HTPC hs.WriteLog "DVDL", "Components set for HTPC Trailers" hs.WaitSecs 7 'New Trailer Command follows hs.launch "C:\Program Files\Zoom Player\zplayer.exe", "/ADD:G:\Video\PLAYLISTS\" &cstr(SOUNDTRACK) &".ZPL /AR:4 /SPEAKER:0 /LOCKFS /VOL:90 /PLAY /MOUSEOFF /Q" hs.WriteLog "DVDL", "Trailer command= " &cstr(TRAILERCOMMAND) hs.WriteLog "DVDL", "Pausing "&cstr(TRAILERLENGTH) & " seconds for trailer viewing" hs.triggerevent "DVDStop" hs.WaitSecs 27 hs.triggerevent "DVDLPlayChangerMovie" hs.WriteLog "DVDL", "Launch pause= " &cstr(LAUNCHPAUSE) hs.WaitSecs cstr(LAUNCHPAUSE) hs.WaitSecs 1 hs.WriteLog "DVDL", "Switching components for Sony DVP-CX777ES" hs.SendIR "TV_Panasonic,Volume_Down,,TV_Panasonic,Mute,,TV_Panasonic,Channel_Up,,,Receiver_Yamaha,Power,TV_Panasonic,TV/Video,,,Receiver_Yamaha,DVD-in_(DVDM),TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,Volume_Down" 'sets components for the CX777ES hs.WriteLog "DVDL", "Components set for DVP-CX777ES" hs.plugin("MLHSPlugin").MLServeCMD "MLZoomPlayer|EXIT" 'just in case Zoom got hung playing something in the playlist hs.triggerevent "DVDBack" hs.WriteLog "DVDL", "Launch from changer complete" '***Launch Movie from HDD*** elseif PREFIX="H" then hs.WriteLog "DVDL", "Launching from HDD" hs.WriteLog "DVDL", "Switching components for HTPC" hs.SendIR "TV_Panasonic,Volume_Down,,TV_Panasonic,Mute,,TV_Panasonic,Channel_Up,,,Receiver_Yamaha,Power,TV_Panasonic,RGB_In,,,Receiver_Yamaha,MD-in,TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,Volume_Down" 'sets components for HTPC hs.WriteLog "DVDL", "Components set for HTPC" hs.WaitSecs 7 'New Trailer Command Follows hs.launch "C:\Program Files\Zoom Player\zplayer.exe", "/ADD:G:\Video\PLAYLISTS\" &cstr(SOUNDTRACK) &".ZPL /AR:4 /SPEAKER:0 /LOCKFS /VOL:90 /PLAY /MOUSEOFF /Q" hs.WriteLog "DVDL", "Trailer command= " &cstr(TRAILERCOMMAND) hs.WriteLog "DVDL", "Pausing " &cstr(TRAILERLENGTH) & " seconds for trailer viewing" hs.WaitSecs cstr(TRAILERLENGTH) 'hs.plugin("MLHSPlugin").MLServeCMD "MLZoomPlayer|EXIT" 'just in case Zoom got hung playing something in the playlist 'hs.waitsecs 1 hs.WriteLog "DVDL", "Movie command= " &cstr(MOVIECOMMAND) 'New HDD Movie Command Follows hs.launch "C:\Program Files\Zoom Player\zplayer.exe", """/ADD:G:\Video\" &cstr(FIXEDTITLE)&""" /AR:3 /SPEAKER:0 /LOCKFS /VOL:90 /PLAY /MOUSEOFF" hs.writelog "DVDL", "Launch from HDD complete" '***Movie is an offline DVD*** elseif PREFIX="O" then hs.WriteLog "DVDL", "Preparing for Single DVD playback" hs.SendIR "DVD_Panasonic,Play" hs.WriteLog "DVDL", "A-310 Powered-On" hs.WriteLog "DVDL", "Switching components for HTPC trailers" hs.SendIR "TV_Panasonic,Volume_Down,,TV_Panasonic,Mute,,TV_Panasonic,Channel_Up,,,Receiver_Yamaha,Power,TV_Panasonic,RGB_In,,,Receiver_Yamaha,MD-in,TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,Volume_Down" 'sets components for HTPC hs.WriteLog "DVDL", "Components set for HTPC Trailers" hs.WaitSecs 7 'New Trailer Command Follows hs.launch "C:\Program Files\Zoom Player\zplayer.exe", "/ADD:G:\Video\PLAYLISTS\" &cstr(SOUNDTRACK) &".ZPL /AR:4 /SPEAKER:0 /LOCKFS /VOL:90 /DVD /PLAY /MOUSEOFF /Q" hs.Launch cstr(TRAILERCOMMAND) hs.WriteLog "DVDL", "Trailer command= " &cstr(TRAILERCOMMAND) hs.WriteLog "DVDL", "Pausing "&cstr(TRAILERLENGTH) & " seconds for trailer viewing" hs.WaitSecs cstr(TRAILERLENGTH) hs.WriteLog "DVDL", "Switching components for Panasonic A-310" hs.SendIR "TV_Panasonic,Volume_Down,,TV_Panasonic,Mute,,TV_Panasonic,Channel_Up,,,Receiver_Yamaha,Power,TV_Panasonic,TV/Video,,,Receiver_Yamaha,DTV-in_(DVDS),TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,Volume_Down" hs.WriteLog "DVDL", "Components set for Panasonic A-310" hs.plugin("MLHSPlugin").MLServeCMD "MLZoomPlayer|EXIT" 'just in case Zoom got hng playing something in the playlist hs.writelog "DVDL", "Launch from single-disk player complete" '***Movie is an offline Video Cassette*** elseif PREFIX="V" then hs.WriteLog "DVDL", "Preparing for VCR playback" hs.WriteLog "DVDL", "Switching components for HTPC trailers" hs.SendIR "TV_Panasonic,Volume_Down,,TV_Panasonic,Mute,,TV_Panasonic,Channel_Up,,,Receiver_Yamaha,Power,TV_Panasonic,RGB_In,,,Receiver_Yamaha,MD-in,TV_Panasonic,TV/Video,,,TV_Panasonic,TV/Video,,,TV_Panasonic,Volume_Down" 'sets components for HTPC hs.WriteLog "DVDL", "Components set for HTPC Trailers" hs.WaitSecs 7 'New Trailer Command Follows hs.launch "C:\Program Files\Zoom Player\zplayer.exe", "/ADD:G:\Video\PLAYLISTS\" &cstr(SOUNDTRACK) &".ZPL /AR:4 /SPEAKER:0 /LOCKFS /VOL:90 /DVD /PLAY /MOUSEOFF /Q" hs.WriteLog "DVDL", "Trailer command= " &cstr(TRAILERCOMMAND) hs.WriteLog "DVDL", "Pausing "&cstr(TRAILERLENGTH) & " seconds for trailer viewing" hs.WaitSecs cstr(TRAILERLENGTH) hs.WriteLog "DVDL", "Switching components for the VCR" hs.SendIR "TV_Panasonic,Volume_Down,,TV_Panasonic,Mute,,TV_Panasonic,Channel_Up,,,Receiver_Yamaha,Power,TV_Panasonic,TV/Video,,,Receiver_Yamaha,VID1,TV_Panasonic,TV/Video,,,TV_Panasonic,Volume_Down" hs.WriteLog "DVDL", "Components set for VCR" hs.plugin("MLHSPlugin").MLServeCMD "MLZoomPlayer|EXIT" 'just in case Zoom got hung playing something in the playlist hs.writelog "DVDL", "Launch from VCR complete" else end if '***End of script*** hs.SendIR "TV_Panasonic,Volume_Up" hs.WriteLog "DVDL", "DVDL script complete" end sub
EDIT: updated the trailer command for the changer (had the old one still in there)
EDIT2: 21 JAN 05, 08:54 - Fixed the trailer and HDD movie commands. HS did not like the old commands. The commands in the current state limit you to having all of your movies on a single HDD (although, perhaps one of DVDL's custom fields could be populated with a drive letter and that info be brought over to the HS script and use something like cstr(DRIVE) in place of 'G' like I have now. Another way would be to send the command back to MLServer, since it is more tolerant of odd characters in a variable and use {{FILENAME}} (a variable created in the existing default play command) and have HS kick-off an event with
MLServeCmd.MLFileOpen|C:\Program Files\Zoom Player\zplayer.exe~/add:{{FILENAME}} /F /Q /PLAY /MOUSEOFF /DVD
or the like in the MLHSPlugin tab box (since launching a complex MLServe command from a HS script doesn't always seem to work for me). Might be the way to go for the trailer too (might be simpler in the long run)
EDIT3:uncommented a systemspeak
Thu Jan 20, 2005 4:19 pm
That is SO beautiful it brought tears to my eyes. :cry:
Great work! I look forward to borrowing liberally from it!
:D
jrfuda
Thu Jan 20, 2005 4:32 pm
Glad you like it! :)
I need to double check. There may be a problem with
and
hs.launch cstr(MOVIECOMMAND)
I need to do more testing. Another mistake in the script made me think they were working. I need to confirm...
jrfuda
Updated!
Fri Jan 21, 2005 10:04 am
I fixed the problems with the script, and now it REALLY works. See the first post for the correct script and some suggestions for use on others' systems.
bwally
Fri Jan 21, 2005 1:36 pm
hey John!
this looks great!
just wondering, is there anything special that needs to be done to setup the playback of the trailers in DVDL ? Are you using DVDProfiler to get the info into DVDL ?
i just bought myself a CX777ES for christmas :)
i have put in 2 DVD's so far :shock:
this little treat of yours couldn't have come along at a better time.
steve
jrfuda
Fri Jan 21, 2005 2:26 pm
Steve, you have HomeSeer, right?
The "trailers" I have playing are just playlists that play while the 777 is turning its wheels - They consist of 3 parts. A Welcome to our Theater" segment, a soundtrack segment, and a "feature presentation segment.
I have not recorded actual movie trailers yet. If I do, I will make a seperate script for it. I'll use the same MLserve play movie command, but I'd have the HS_Run part run a different script, say DVDTrailer.txt.
Remember, in DVDL you can specify both a default play movie and default play trailer command, so all you have to do is fill-in the box.
I forsee trailers having 3 posssible locations - changer (using the title trick I think gregoryx mentioned elsewhere) the HDD, and unavalable.
The "DVDTrailer.txt" script should look similair to my first script, but shorter (it will have 3 major "if/ifelse statements instead of 4, and only have a single play command - wheras the DVDLobby.txt script lauchnes a pre-move trailer and then the movie - this one will onlt launch one thing).
Another option, since the location of each trailer will vary soooo much, is to use the alternate play trailer command box that each DVD entry has. For example. Have it pop-up a "Trailer not available" message box for movies with no preview trailers. Have all the DVDs that actualy contain a trailer on them (and some even have some for other movies) use the disc direct command to start the disc in the proper title (I watched Shrek2 the other day which contained non-avoidable trailers for Shark Tale and Madagascar - there was so much junk at the beginning of that DVD that the actual movie was TITLE 10!!!!! - so perhaps I need to make one of the CUSTOM# entried a title entry for discs like this and add that variable into my play command - but that's another project)... anyway, that was to point-out how the title command could be used to star the disc in a certain spot.
EDIT: I manually entered all my DVD's using the multiple CTRL-A trick (opens up multiple add from internets so you can perform multiple searhes at once). I then tweak everything in MS access, which is much faster for "standardizing" everything.
Return to “How are you using DVDLobby?”
