gstone
probs
Sun May 25, 2008 4:06 pm
I am using the videostorm pluing with a Video Storm 6x2.
At current I have 2 devices connected. Both are using Component Video and TOSLink audio.
If I use the buttons to change in puts everthing works fine. But if I use the plug in nothing works for basic commands although you can see the front panel blink when it recieves a command.
If I switch it to ADV. mode I can switch vide individually but it will not switch the audio.
I am running the latest of everything.
Always ask! You can't stay dumb forever!
gstone
Sun May 25, 2008 4:22 pm
Alright I must be doing the commands wrong.
If I have 2 devices both connected by component video (red,grenn,blue) and TOSLink audio(optical)....
What mode should I bee running in? And what coomands would I use to switch audio and video 1 to out 1 or out 2?
And command to switch aud and vid 2 to out 1 or out 2?
I think I am confused!
gstone
Sun May 25, 2008 5:42 pm
All is good. Actually founbd the answer in a old post I started about something similar.
Should have searched before I spoke.
Sun May 25, 2008 10:02 pm
gstone, can you update the wiki with whatever you found? If it fouled you up, it will someone else. Thanx
gstone
Tue May 27, 2008 8:54 am
I added it.
Return to “Video Storm”
