lyfelyte
External SWF Screen SAver
Sun Sep 20, 2009 1:08 pm
This might be simple answer, but I have a screen saver from www.missingkidsaver.com, which when used as a screen saver outside of Mainlobby will load information from the internet about current missing children. I wanted to use this in a Mainlobby scene, but when I use the SWF file as a button or overlay, the flash appears, but it will not pull the information from the web as it would outside of ML. It just says loading... and then finally tells me that there is no internet connection, which there is, so ML must be blocking it somehow.
I'm guesing that while in Mainlobby, the only way I can get this to work would be to create a server side plugin. If someone has time to download the screen saver, you'll see what I mean. And if anyone has any suggestions, please let me know.
Thanks,
TD
Return to “MLS files/Buttons/Icons/Backgrounds/SWF/3rd Party Apps/Device Files”
