pyspilf
Flash ActionScript 2 Error
Wed Apr 29, 2009 12:03 pm
Guys,
I've been doing lots of reading on this forum about creating custom flash objects for use in ML, and have managed to get a dynamic text containing a value, like for example: _root.MLHSPlugin_]53_value
However, and I thought I understood this would work equally well in ActionScript, I get a syntax error for this statement.
var power = _root.MLHSPlugin_]53_value;
Can anyone understand why? Is is to do with the "]" symbol? Any idea how to get around this?
Thanks a lot!
Sandro
There is a thin line between exposure and visibility...
Wed Apr 29, 2009 12:08 pm
I would start there. Try using variables without the bracket and see how things go.
pyspilf
Thu Apr 30, 2009 2:22 am
Mario,
I have tried and I believe the issue is that ActionScript considers the ] symbol as a part of an array delimiter... I have found one workaround but it seems a bit cumbersome:
I assign the MLHS variable that contains the ] character to a dynamic text object, say myText, and then in ActionScript I use myText.text to retrieve the value... it works, BUT it would mean if I need to use 10 of these variables for example, I will need 10 hidden dynamic text objects to get the value. Doesn't seem very efficient, does it?
There must be another way to do this... I was hoping some Flash expert may have some suggestions. Unfortunately, these variables come from HomeSeer and I cannot change the ] character. It is a virtual device identifier assigned by HomeSeer and not available for the user to modify.
I suppose I could also create lots of shadow ML server variables with more ActionScript friendly names by copying all of the ones that come in via MLHS... again, a bit cumbersome.
Cheers
Sandro
Thu Apr 30, 2009 7:02 am
Hi Sandro,
I know this has been an issue for other HS users. I know there is a workaround. I would search this forum and the HS/Mainlobby forum for the answer.
pyspilf
Thu Apr 30, 2009 7:55 am
Mario,
thanks for the suggestion. I searched this forum and could not find anything. I have cross-posted in the HS forum (http://board.homeseer.com/showthread.ph ... post869864) - maybe Krumpy or someone who has had this issue will pick it up
Cheers
Sandro
Thu Apr 30, 2009 8:12 am
If I remember correctly, you would remove the current device using the ], then add another device as a placeholder to take that position. Then re-add your original device, so it uses the next character in HomeSeer's lineup.
pyspilf
Thu Apr 30, 2009 8:20 am
Mario,
I wish I could... I have tons of physical and virtual devices that use [, ], \, etc.... all the most code-unfriendly IDs!!!!! It would take forever to re-assign all the IDs
What a pain. But, apart from this, I am really enjoying ML and HS, and getting good value out of MLHS, so I am happy all the same :-)
Fri May 01, 2009 2:49 am
New beta of MLHSPlugin that now can use device names in addition to x10 house/unit codes.
This will resolve your issue - hopefully - it's beta!
http://board.homeseer.com/showthread.php?t=135709
pyspilf
Fri May 01, 2009 5:59 am
Krumpy, thanks, this is much appreciated!!! I will give it a spin and let you know!
Cheers
wireless
Fri May 01, 2009 10:07 am
Can you actually use device names in a command? ex: ToggleDevoce:Foyer Lamp
Doesn't seem to work. MLServer log shows the command but HS doesn't
