simonmason
Fanart failing
Wed Jul 04, 2018 8:09 pm
It seems like Fanart lookup is failing all of the time. I am not getting much in the log other than "Using System Default". Assuming it is stillusing fanart.tv then all of these artists are on there and should be found.
Line 43238: 7/4/2018 8:03:26 PM GetArtistFanart Requesting Toto
Line 43254: 7/4/2018 8:03:26 PM GetArtistFanart Using System Default Images/InConcert.jpg
Line 43255: 7/4/2018 8:03:26 PM GetArtistFanart Using System Default Thumbnail
Line 43256: 7/4/2018 8:03:26 PM GetArtistFanart Using System Default HDMusicLogo
Line 43257: 7/4/2018 8:03:26 PM GetArtistFanart Using System Default MusicLogo
Line 43258: 7/4/2018 8:03:26 PM GetArtistFanart Using System Default MusicBanner
Line 43260: 7/4/2018 8:03:30 PM GetArtistFanart Requesting The Emotions
Line 43263: 7/4/2018 8:03:30 PM GetArtistFanart Using System Default Images/InConcert.jpg
Line 43264: 7/4/2018 8:03:30 PM GetArtistFanart Using System Default Thumbnail
Line 43265: 7/4/2018 8:03:30 PM GetArtistFanart Using System Default HDMusicLogo
Line 43266: 7/4/2018 8:03:30 PM GetArtistFanart Using System Default MusicLogo
Line 43267: 7/4/2018 8:03:30 PM GetArtistFanart Using System Default MusicBanner
Simon D. S. Mason
Synergy_Tech
Re: Fanart failing
Thu Jul 05, 2018 12:14 am
Same here. All fanart searches fail
simonmason
Re: Fanart failing
Thu Jul 05, 2018 8:37 am
Something must have changed on fanart.tv. I am glad that this is not just me as I am having another issue with coverart with Sirius, which I believe is unrelated, and I was starting to think it was something to do with my setup. A lot of my scenes depend on these images as they bring the touchscreen to life. Hopefully Dave can investigate and shed some light on it.
Simon D. S. Mason
Re: Fanart failing
Sat Jul 07, 2018 5:30 pm
Musicbrainz changed their API xml response slightly and that is was is causing the fanart issue. This is fixed in the next release of myServer.
simonmason
Re: Fanart failing
Fri Jul 20, 2018 7:37 am
Bump on this one. I have built all of my touchscreens around coverart so it looks very sad at present! Thanks.
Simon D. S. Mason
Re: Fanart failing
Fri Jul 20, 2018 11:30 am
I have not forgot about this. As was mentioned the fix is the the next server release. The next server release has some major updates to it and it is going through a lot of testing to make sure it doesn't cause any issues.
Synergy_Tech
Re: Fanart failing
Fri Jul 20, 2018 7:22 pm
Haha....yeah I'm tired of looking at that default crowd. :D
simonmason
Re: Fanart failing
Sat Jul 21, 2018 7:54 am
While you are updating myserver can you look at some interface updates. For example, sorting command macros alphabetically?
Simon D. S. Mason
simonmason
Re: Fanart failing
Fri May 24, 2019 6:44 pm
I am setting up a new Spotify process and I noticed I can't get GetArtistFanArt working. It always defaults to the noimage. I am executing the following command:
GetArtistFanart|Artist~{{hs3_squeezebox_artist}}~{{music_currentfanart_cha2}}
When I go to fanart.tv and enter the artist name I am able to find it.
I notice that the Internet Radio app is looking up fan art fine.
Simon D. S. Mason
Re: Fanart failing
Sat May 25, 2019 3:36 pm
Sorry, Command Builder has the syntax wrong.
Change GetArtistFanart|Artist~{{hs3_squeezebox_artist}}~{{music_currentfanart_cha2}}
To GetArtistFanart|{{hs3_squeezebox_artist}}~{{music_currentfanart_cha2}}
simonmason
Re: Fanart failing
Sun May 26, 2019 12:24 pm
I am still having issues with it. I am using:
But music_currentfanart_CHA2 is not updating. In the log file attached it seems to indicate that it is always going with the default.
Also, where are the thumbnail, HDMusiclogo and Musiclogo addresses stored when this command is running? Thanks.
Simon D. S. Mason
simonmason
Re: Fanart failing
Fri Jun 14, 2019 7:30 pm
Bump on this one. I would like to get the fan art working again. Thanks.
Simon D. S. Mason
simonmason
Re: Fanart failing
Sun Nov 03, 2019 4:24 pm
Double bump.
I may be doing something wrong below but I cannot get this to work so would appreciate some pointers. Would really like to get fan art look up working.
Simon D. S. Mason
Return to “Advanced Techniques”
