sonypoolplr
Modify Device Settings
Sat Apr 14, 2018 9:04 am
I see on the About scene of the iPhone web app that the Modify Device Settings button call a client command of ModifySettings. I don't see that command listed in the Command Macros of mySerever. This is the same for the Reset Settings button. Should they be there? If so, what should the commands say so that I can add them.
Thank you.
Re: Modify Device Settings
Sat Apr 14, 2018 12:31 pm
Both of those buttons are used only on the native myUI Android. You can just delete them from the scene.
sonypoolplr
Sun Apr 15, 2018 9:12 am
OK thank you. I was looking around at the projects and I see that the myUI.Phones.Sample has a different About scene. Should I be using that one with my iPhone and then set the clientname to what I want?
Sun Apr 15, 2018 9:51 am
The latest samples are representative of what you should / could be using.
Yes, you should set a unique clientname for each device.
And the latest example is the About page.
You can certainly customize it, but the functionality is suggested.
Return to “Advanced Techniques”
