simonmason
Feature Request: Enable CTRL-A in edit fields on server
Sun Sep 17, 2017 1:41 pm
Many (if not all) of the edit fields on the server do not support CTRL-A to select all text. If it is possible to enable CTRL-A it would make things easier when cutting and pasting. Specific examples: the variable search field, the Script editor, etc.
Not a big deal but it would save some time - especially with scripts as I edit them outside of MyServer and then have to select all by dragging the mouse and copying and pasting. Thanks.
Simon D. S. Mason
Re: Feature Request: Enable CTRL-A in edit fields on server
Mon Sep 18, 2017 12:42 pm
Noted. When I'm back in the designer I'll start adding the functionality.
randyf
Tue Sep 19, 2017 12:56 pm
I agree that the Ctrl-A option would be a time saver.
Simon - you can also right-click on the field and use the Select All option, then Ctrl-C / Ctrl-V, without having to use the mouse to select all of the text.
ffneil
Tue Sep 19, 2017 9:51 pm
To one up that, it would be nice if we could draw a box to select items and/or to select items and group them.
simonmason
Tue Sep 19, 2017 10:24 pm
The right click and Select All does work. Thanks for the tip. I am so used to CTRL-A that I overlooked the obvious.
Simon D. S. Mason
Return to “Advanced Techniques”
