sonypoolplr
Start or Stop Program with myServer
Mon May 01, 2017 2:50 pm
I would like to shutdown another program when I shutdown myServer, and start it back up when myServer is started. I was wondering if anyone knows what the syntax is for this, and also, where do I put the commands in myServer?
Thank you
Re: Start or Stop Program with myServer
Mon May 01, 2017 5:24 pm
Synergy_Tech
Wed May 03, 2017 9:25 pm
I usually put that sort of thing into the system.startup or system.shutdown macros. Syntax would be something like:
Run|Program~<Program.exe>~<optional arguments>
or
Stop|<program name> (example:chrome)
You can also do something like:
Run|taskkill.exe~/F /IM chrome.exe
The syntax may not be exactly correct but I can usually find what I need in command builder
sonypoolplr
Wed May 03, 2017 9:35 pm
Thank you. So the system.startup and system.shutdown macros get triggered without any extra commands or automation rules needed from me? I was looking around to see if there was something that was triggered at startup and shutdown but I couldn't find it.
sonypoolplr
Thu May 04, 2017 9:04 am
I am trying the following in the System.Startup macro but I keep getting this error:
5/4/2017 8:57:36 AM Process Primary [1] Error at MoveNext at line #7426 - The system cannot find the file specified
I have tried:
Run|Program~C:\Program Files (x86)\HomeSeer\Speaker\Speaker.exe
Run|Program~"C:\Program Files (x86)\HomeSeer\Speaker\Speaker.exe"
Run|Program~Program Files (x86)\HomeSeer\Speaker\Speaker.exe
Run|Program~Speaker.exe
Run|C:\Program Files (x86)\HomeSeer\Speaker\Speaker.exe
Run|"C:\Program Files (x86)\HomeSeer\Speaker\Speaker.exe"
None of them are working. Anymore help with this would be greatly appreciated.
Thank you
sonypoolplr
Thu May 04, 2017 9:20 am
As an update, I got this to work:
MLFileOpen|C:\Program Files (x86)\HomeSeer\Speaker\Speaker.exe
But I cannot find the command to shut it down when myServer shuts down.
Thank you
sonypoolplr
Thu May 04, 2017 1:36 pm
Thank you everyone for the help.
Synergy_Tech
Sat May 06, 2017 10:33 pm
I forgot about mlfileopen, that's an old one. I thought the Run command was the replacement. Did you get it all working?
sonypoolplr
Sun May 07, 2017 10:26 am
Yes I am using: MLFileOpen|C:\Program Files (x86)\HomeSeer\Speaker\Speaker.exe to open it and the taskkill to close it. I haven't had to do a restart yet, I was only testing it through myServer so hopefully it works like it should.
Return to “Advanced Techniques”
