simonmason
Macro parameter help
Sun Apr 16, 2017 10:22 pm
I am trying to create a Command Macro that accepts a parameter.
I have called the macro Sirius.PlayChannel and I want it to execute the external program sirius.exe with a parameter that I pass it. For example - if I call Sirius.PlayChannel~36 I want it to Run the program sirius.exe and pass it 36 as a parameter.
I have tried a number of versions of the macro but none seem to work. I have tried:
Run|sirius.exe <p1>
Run|sirius.exe~<p1>
etc.
What is the correct format?
sirius.exe is in the Myserver main folder. I have another test command macro setup with Run|sirius.exe~36 and it passes the 36 to sirius.exe and works fine. Obviously I am missing something here?? Thanks.
Simon D. S. Mason
Synergy_Tech
Re: Macro parameter help
Wed Apr 19, 2017 11:12 pm
Where is the parameter being called from?
Thu Apr 20, 2017 12:03 pm
<<>> Double Arrows Double surrounding arrows are used to signify variables local to the application/client instance.
Is that what you are trying to do?
http://allonis.com/template-features/pr ... mmand.html
simonmason
Sun Apr 23, 2017 7:53 am
I am not sure if this is the same thing, although I have developed a workaround to my issue which is definitely less elegant.
I was trying to call command macros on the server from the client with a parameter. My issue was with getting the right syntax to make it execute. The window for editing macros on the server says "When creating new macros enter one Server Command per line. Macro syntax will automatically be inserted when saved or collapsed. If your Macro accepts parameters then insert parameters using <P1>,<P2>,<Pn> syntax.
Let's say I have a command macro, "Sample.Macro" and it executes one command "do command".
Normally I would call it with "sample.macro" and it would run.
Now let's say the command takes a parameter - "do command <P1>"
I tried calling it in a number of different ways but none of them pass the parameter, for example if I was trying to pass it the number 1:
"sample.macro~1" - nothing happens
"sample.macro" - the macro runs with no parameter
"sample.macro 1" - nothing happens
Simon D. S. Mason
Tue May 23, 2017 8:16 pm
usage is
sample.macro|p1value~p2value~p3value etc..
Inside the macro
p1value is <P1>
p2value is <P2>
p3valus is <P3>
etc.
Thu Jan 31, 2019 8:54 pm
That is awesome. Just discovered this. Saves so much nonsense code!
Return to “Advanced Techniques”
