jeeperboy
New Member
New Member
Issue with HUE color
Fri Mar 15, 2019 6:28 pm
I cant get the color to change on my HUE lights using this command but no luck
Lighting|115~Color~255~100~47000 I am trying to change to color temp to 47K
Any ideas ?
Re: Issue with HUE color
Sun Mar 17, 2019 3:08 pm
What shows in the Hue driver event log when you send the command?
jeeperboy
New Member
New Member
Sun Mar 17, 2019 8:15 pm
Hi Dave,
I tried the same command but for a different light this time a Lightstrip Plus model # LST002 and the command worked fine.
After doing a little looking around I found the Hue plugin is not discovering the following:
Hue color spot Model Number LCT003
Hue ambiance lamp Model Number LTW015
Hue ambiance down light Model Number LTD005
If I put the lights into groups I can control them off and on but no other features.
Log is attached.
PhilipsHue-3-17-2019.log
(33.22 KiB) Downloaded 41 times
Mon Mar 18, 2019 5:06 pm
The driver has been updated to support those missing bulb types.
jeeperboy
New Member
New Member
Mon Mar 18, 2019 5:46 pm
That work they now show up with the discovery but they still will not change color temperature.
logs attached.
Thanks for the speedy turnaround you guys rock !!
PhilipsHue-3-18-2019.log
(67.29 KiB) Downloaded 35 times
Mon Mar 18, 2019 7:02 pm
I see what is happening. You're trying to change the color temperature of the bulb using the Color command. The Color command is only valid for setting colors for RGB (HSB) bulbs. I'm going to have to add a new command called ColorTemp that will allow you to set the color temperature correctly.
jeeperboy
New Member
New Member
Mon Mar 18, 2019 8:12 pm
Thanks everything else on the driver is working like a champ !!
Mon Mar 18, 2019 9:23 pm
Driver updated again. There is a new ColorTemp command now, Lighting|<<id>>~ColorTemp~Temp (where temp is 137 .. 500)
I do not have any bulbs that support changing color temp so you'll have to let me know if it works.
jeeperboy
New Member
New Member
Mon Mar 18, 2019 9:34 pm
It works thanks I will give it a full testing later this eve. thanks for the fast turn around !!
Return to “Lighting Family Device Drivers”
