Re: Russound Driver Released
Wed May 07, 2014 5:20 pm
The Russound driver was updated today. Today's changes added support for more keypad events coming from MCA keypads. If you have an MCA-3 or MCA-5 see if this driver is now picking up all the keypad presses.
rileydog
Fri May 09, 2014 12:03 pm
Perfect - I see all the keys pressed (except the home button on the keypads) are calling macros! I can't see why I would need a home button macro so no biggie. Great job. I also noticed the controller display is being captured in variables (artist, song, etc.) - didn't notice that before. I use the Myro:Bridge which is incredible - it displays meta data from my whole house sonos on the displays and it responds to key commands on the keypads (next song, pause, etc.). With that meta data, now ML reads then into variables so I am able to see what is playing in each zone via ML scenes. Myro just release the Myro:Air which is an Airplay device so I can play iTunes through the whole house and all meta data goes to the controllers and thus, to ML through the device driver... Really nice!
The keypad message still doesn't work but I am sure that is a lot more work. Thanks!
Fri May 09, 2014 12:16 pm
Ok, that is great progress. If you can run an experiment for me. Press the home button on a keypad and see if it generates an Unknown Event type message in the Russound log. If it does send me the log and I will had that event into the mix.
I didn't do any work with the message command. That will take some more testing.
rileydog
Fri May 09, 2014 9:00 pm
Home is working - I had the macro wrong... So, all is well!
Russound Driver Gone Wild with Russound update
Sat Jul 12, 2014 10:00 pm
Updated my MCA-C5 to Russound firmware version 7.01 and the MainLobby driver has gone into orbit. One command fired in Mainlobby using RNet Driver triggers 1000's of lines of code (endless loop?) under "Process Response - Event Messages". Eventually, Russound Driver locks up MLServer and I have to restart. Maybe time for a fresh look at RNet and IP-RIOS drivers. Dave, email sent to look at through TeamViewer when you have the time.
**Never mind - had to set my second controller ID switch to "1" to perform the update. Forgot to reset the switch to "2" when I restarted the two controllers. Must have been cross-talk...
rileydog
Sat Jul 12, 2014 11:45 pm
I am using firmware 7.01 with (2) MCA-C5's with no issues...
bigbrother
Sun Jul 20, 2014 12:36 pm
If I want to change to the NEXT song playing in MuL by using the Russound keypad "Next" button, for all of the zones,
Using Command Macros,
Command: Conditional|IsEqual##av_5_zone_1_source##5##MusicLobby|NextTrack~{{music_activesource_{{clientname}}}}##
However, I want it to be universal for all zones, but unique to the source.
IE: when Russound.Keypad.Next (any zone 1-6) (source 5) is pressed, MusicLobby|NextTrack~{{music_activesource_{{clientname}
How do I write this?
Thanks BB
Sun Jul 20, 2014 3:47 pm
The CAV driver should automatically be passing in the AV device ID and zone where the press came from as <P1> and <P2> parameters. So your command can become something like
If|IsEqual##{{av_<P1>_zone_<P2>_source}}##5##MusicLobby|NextTrack~{{music_activesource_{{clientname}}}}##
bigbrother
Sun Jul 20, 2014 5:46 pm
It does for an individual Zone Source.
But I am trying to make it work so Source 5 on zones 1-6 do the same thing.
Do I need to write a conditional line for all 6 zones? Do I create a command macro for that?
IE:
Conditional|IsEqual##av_5_zone_2_source##5##MusicLobby|NextTrack~{{music_activesource_{{clientname}}}}##
Conditional|IsEqual##av_5_zone_3_source##5##MusicLobby|NextTrack~{{music_activesource_{{clientname}}}}##
Conditional|IsEqual##av_5_zone_4_source##5##MusicLobby|NextTrack~{{music_activesource_{{clientname}}}}##
Conditional|IsEqual##av_5_zone_5_source##5##MusicLobby|NextTrack~{{music_activesource_{{clientname}}}}##
Conditional|IsEqual##av_5_zone_6_source##5##MusicLobby|NextTrack~{{music_activesource_{{clientname}}}}##
Sun Jul 20, 2014 7:00 pm
No, you don't need 6 conditionals because the one conditional is dynamic based on the parameters being passed to the macro.
bigbrother
Sun Jul 20, 2014 7:40 pm
Is that command
Placed in Command Marcos?
Do I use the Macro Name Russound.Keypad.Next?
Thanks BB
Sun Jul 20, 2014 8:28 pm
Yes create a Command macro called Russound.Keypad.Next and set the MLServer command to
Note that "If|" is the same as "Conditional|"
The other macro commands called from the driver include the following: All are passed DeviceID and Zone.
Russound.Keypad.Source
Russound.Keypad.Prev
Russound.Keypad.Plus
Russound.Keypad.Minus
Russound.Keypad.Power
Russound.Keypad.Pause
Russound.Keypad.Fav1
Russound.Keypad.Fav2
Russound.Keypad.VolUp
Russound.Keypad.VolDown
Russound.Keypad.VolUpHold
Russound.Keypad.VolDownHold
Russound.Keypad.Home
Russound.Keypad.Menu
Russound.Keypad.Select
Russound.Keypad.SelectItem
randyf
Mon Jul 21, 2014 7:38 pm
I'm trying to get my CAV66 configured to use MusicLobby for music tracks/playlists and I have the MusicLobby sources configured to use 3 of the outputs on my M-Audio Delta sound card. What is the trick to getting the following items working:
1. Associating a source from the CAV66 to a source within MusicLobby - when the user presses the Source button on the Uno S2 keypad, I would like it to cycle thru the sources from MusicLobby.
2. How can I add logic to have the Uno S2 F1 (or F2) button display the playlists for the current MusicLobby source so that the person can select a different playlist for that CAV zone?
3. How do I get the current track artist/song title displayed in the Uno S2 message area?
Randy
randyf
Command Macro not getting correct zone parameter?
Mon Aug 11, 2014 8:54 pm
I'm working to create the interaction with my CAV66 and UNO-S2 keypads and ML. I have Russound.Keypad.Next and Russound.Keypad.Previous command macros created with this debug line in them for testing purposes:
Logger|Log~CAV~KEYPAD~Russound.Keypad.Next~P1=<P1>, P2=<P2>
Logger|Log~CAV~KEYPAD~Russound.Keypad.Previous~P1=<P1>, P2=<P2>
It seems like the zone parameter <P2> is not being passed to the command macro properly - it seems to only send 1 as the value. The way I tested is by turning on the keypad power, pressing the next button, pressing the previous button, and finally pressing the power button again. Here is Russound log output for the test - you can see that when the power button is pressed, it "sees" the right CAV controller (in this case, 2) and it shows zone 5, which is the keypad I was testing with:
8/11/2014 8:27:38 PM ProcessResponse Event Message [F0 01 00 7F 01 04 00 05 03 02 00 04 02 04 03 6C 00 00 00 00 00 01 0F F7] 8/11/2014 8:27:38 PM ProcessResponse Uno Power Button Released. [6C] 2/0/4@4/3 8/11/2014 8:27:38 PM MacroExists Looking for Russound.Keypad.Power 8/11/2014 8:27:38 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 06 02 04 00 00 00 01 00 01 00 02 23 F7] 8/11/2014 8:27:38 PM ProcessResponse Data Message Controller:2 Zone:5 BGColor=2 8/11/2014 8:27:38 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 00 02 04 00 00 00 01 00 01 00 0A 25 F7] 8/11/2014 8:27:38 PM ProcessResponse Display Message [F0 01 04 7D 01 00 7F 06 41 00 00 00 05 4B F7] 8/11/2014 8:27:38 PM ProcessResponse Source 1 8/11/2014 8:27:38 PM ProcessResponse Event Message [F0 01 04 7D 01 00 7F 05 02 01 00 02 01 00 DC 00 01 00 04 00 01 2D F7] 8/11/2014 8:27:38 PM ProcessResponse Zone Power Event Controller:2 Zone:5 Power=1 8/11/2014 8:27:38 PM ProcessResponse Event Message [F0 00 00 7F 01 00 7F 05 02 01 00 02 01 00 CB 00 01 00 01 00 00 37 F7] 8/11/2014 8:27:38 PM ProcessResponse Update System On Event Controller:1 Zone:1 8/11/2014 8:27:39 PM ProcessResponse Set Data Message [F0 00 04 7D 01 00 7F 00 02 01 01 02 01 01 00 00 01 00 10 00 00 64 00 48 65 6C 6C 6F 00 5A 5A 5A 5A 5A 5A 5A 7C F7] 8/11/2014 8:27:39 PM ProcessResponse Event Message [F0 7E 04 7F 01 00 7F 05 02 01 00 02 01 00 C8 00 01 00 01 00 00 3C F7] 8/11/2014 8:27:39 PM ProcessResponse Update Source Selection Event Controller:2 Zone:5 Data=1 8/11/2014 8:27:39 PM ProcessResponse Event Message [F0 01 7D 00 01 00 7F 05 02 01 00 02 01 00 27 00 7F 04 00 00 01 39 F7] 8/11/2014 8:27:39 PM ProcessResponse Unknown Event [27] 1/0@1/0 8/11/2014 8:27:40 PM ProcessResponse Event Message [F0 7E 00 7F 00 00 7F 05 02 01 00 02 01 00 C5 00 00 00 01 00 00 39 F7] 8/11/2014 8:27:40 PM ProcessResponse Unknown Event [C5] 1/0@1/0 8/11/2014 8:27:40 PM ProcessResponse Event Message [F0 7E 00 7F 00 00 7F 05 02 01 00 02 01 00 C5 00 00 00 01 00 00 39 F7 F0 7F 00 7F 00 00 7F 00 03 04 04 03 02 04 00 00 00 01 00 01 00 01 1A F7] 8/11/2014 8:27:40 PM ProcessResponse Unknown Event [C5] 1/0@1/0 8/11/2014 8:27:53 PM ProcessResponse Event Message [F0 7E 00 7F 00 00 7F 05 02 01 00 02 01 00 C8 00 00 00 00 00 00 35 F7] 8/11/2014 8:27:53 PM ProcessResponse Update Source Selection Event Controller:1 Zone:1 Data=0 8/11/2014 8:28:03 PM ProcessResponse Event Message [F0 01 00 7F 01 04 00 05 03 02 00 04 02 04 03 68 00 00 00 00 00 01 0B F7] 8/11/2014 8:28:03 PM ProcessResponse Uno Next Button Released. [68] 2/0/4@4/3 8/11/2014 8:28:03 PM MacroExists Looking for Russound.Keypad.Next 8/11/2014 8:28:03 PM ProcessResponse Event Message [F0 01 7D 00 01 00 7F 05 02 01 00 02 01 00 0E 00 00 04 00 01 01 22 F7] 8/11/2014 8:28:03 PM ProcessResponse Unknown Event [0E] 1/0@1/0 8/11/2014 8:28:08 PM ProcessResponse Event Message [F0 01 00 7F 01 04 00 05 03 02 00 04 02 04 03 67 00 00 00 00 00 01 0A F7] 8/11/2014 8:28:08 PM ProcessResponse Uno Previous Button Released. [67] 2/0/4@4/3 8/11/2014 8:28:08 PM MacroExists Looking for Russound.Keypad.Previous 8/11/2014 8:28:08 PM ProcessResponse Event Message [F0 01 7D 00 01 00 7F 05 02 01 00 02 01 00 0F 00 00 04 00 01 01 23 F7] 8/11/2014 8:28:08 PM ProcessResponse Unknown Event [0F] 1/0@1/0 8/11/2014 8:28:41 PM ProcessResponse Event Message [F0 7E 7D 00 01 00 7F 05 02 01 00 02 01 00 C8 00 01 00 01 00 00 36 F7] 8/11/2014 8:28:41 PM ProcessResponse Update Source Selection Event Controller:2 Zone:126 Data=1 8/11/2014 8:28:53 PM ProcessResponse Event Message [F0 7E 00 7F 00 00 7F 05 02 01 00 02 01 00 C8 00 00 00 00 00 00 35 F7] 8/11/2014 8:28:53 PM ProcessResponse Update Source Selection Event Controller:1 Zone:1 Data=0 8/11/2014 8:29:41 PM ProcessResponse Event Message [F0 7E 7D 00 01 00 7F 05 02 01 00 02 01 00 C8 00 01 00 01 00 00 36 F7] 8/11/2014 8:29:41 PM ProcessResponse Update Source Selection Event Controller:2 Zone:126 Data=1 8/11/2014 8:29:53 PM ProcessResponse Event Message [F0 7E 00 7F 00 00 7F 05 02 01 00 02 01 00 C8 00 00 00 00 00 00 35 F7] 8/11/2014 8:29:53 PM ProcessResponse Update Source Selection Event Controller:1 Zone:1 Data=0 8/11/2014 8:30:23 PM ProcessResponse Event Message [F0 01 00 7F 01 04 00 05 03 02 00 04 02 04 03 6C 00 00 00 00 00 01 0F F7] 8/11/2014 8:30:23 PM ProcessResponse Uno Power Button Released. [6C] 2/0/4@4/3 8/11/2014 8:30:23 PM MacroExists Looking for Russound.Keypad.Power 8/11/2014 8:30:23 PM ProcessResponse Set Data Message [F0 01 04 00 01 00 7F 00 02 01 01 02 01 01 00 00 01 00 10 00 00 64 00 47 6F 6F 64 62 79 65 00 5A 5A 5A 5A 5A 21 F7] 8/11/2014 8:30:24 PM ProcessResponse Handshake Message [F0 01 00 7F 01 04 00 02 02 02 F7] 8/11/2014 8:30:24 PM ProcessResponse Handshake Message [F0 01 00 7F 01 04 00 02 02 02 F7 F0 01 04 7D 01 00 7F 00 03 04 04 06 02 04 00 00 00 01 00 01 00 00 21 F7] 8/11/2014 8:30:24 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 00 02 04 00 00 00 01 00 01 00 48 63 F7] 8/11/2014 8:30:24 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 04 02 04 00 00 00 01 00 01 00 00 1F F7] 8/11/2014 8:30:24 PM ProcessResponse Data Message Controller:2 Zone:5 Party=0 8/11/2014 8:30:24 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 05 02 04 00 00 00 01 00 01 00 00 20 F7] 8/11/2014 8:30:24 PM ProcessResponse Data Message Controller:2 Zone:5 PartyMaster=0 8/11/2014 8:30:25 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 02 02 04 00 00 00 01 00 01 00 00 1D F7] 8/11/2014 8:30:25 PM ProcessResponse Data Message Controller:2 Zone:5 Shared=0 8/11/2014 8:30:25 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 02 02 04 00 00 00 01 00 01 00 00 1D F7 F0 01 04 7D 01 00 7F 00 02 01 01 02 01 01 00 00 01 00 10 00 00 00 00 00 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 67 F7] 8/11/2014 8:30:25 PM ProcessResponse Data Message Controller:2 Zone:5 Shared=0 8/11/2014 8:30:25 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 02 02 04 00 00 00 01 00 01 00 00 1D F7 F0 01 04 7D 01 00 7F 00 02 01 01 02 01 01 00 00 01 00 10 00 00 00 00 00 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 67 F7 F0 01 04 7D 01 00 7F 05 02 01 00 02 01 00 DC 00 00 00 04 00 01 2C F7] 8/11/2014 8:30:25 PM ProcessResponse Data Message Controller:2 Zone:5 Shared=0 8/11/2014 8:30:25 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 02 02 04 00 00 00 01 00 01 00 00 1D F7 F0 01 04 7D 01 00 7F 00 02 01 01 02 01 01 00 00 01 00 10 00 00 00 00 00 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 67 F7 F0 01 04 7D 01 00 7F 05 02 01 00 02 01 00 DC 00 00 00 04 00 01 2C F7 F0 00 00 7F 01 00 7F 05 02 01 00 02 01 00 CB 00 01 00 00 00 00 36 F7] 8/11/2014 8:30:25 PM ProcessResponse Data Message Controller:2 Zone:5 Shared=0 8/11/2014 8:30:25 PM ProcessResponse Set Data Message [F0 01 04 7D 01 00 7F 00 03 04 04 02 02 04 00 00 00 01 00 01 00 00 1D F7 F0 01 04 7D 01 00 7F 00 02 01 01 02 01 01 00 00 01 00 10 00 00 00 00 00 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 5A 67 F7 F0 01 04 7D 01 00 7F 05 02 01 00 02 01 00 DC 00 00 00 04 00 01 2C F7 F0 00 00 7F 01 00 7F 05 02 01 00 02 01 00 CB 00 01 00 00 00 00 36 F7 F0 7E 00 7F 01 00 7F 05 02 01 00 02 01 00 C8 00 01 00 00 00 00 37 F7] 8/11/2014 8:30:25 PM ProcessResponse Data Message Controller:2 Zone:5 Shared=0 8/11/2014 8:30:26 PM ProcessResponse Event Message [F0 7E 00 7F 00 00 7F 05 02 01 00 02 01 00 C5 00 00 00 00 00 00 38 F7] 8/11/2014 8:30:26 PM ProcessResponse Unknown Event [C5] 1/0@1/0 8/11/2014 8:30:26 PM ProcessResponse Event Message [F0 7E 00 7F 00 00 7F 05 02 01 00 02 01 00 C5 00 00 00 00 00 00 38 F7 F0 7F 00 7F 00 00 7F 00 03 04 04 03 02 04 00 00 00 01 00 01 00 00 19 F7] 8/11/2014 8:30:26 PM ProcessResponse Unknown Event [C5] 1/0@1/0
Here is the output from the MLServer log for the same test, when calling the command macro, where the zone is being shown as 1 instead of 5 as I would expect:
8/11/2014 8:28:03 PM MLProcess Primary [1] (1) [Russound.Keypad.Next|4~1] from [Server] 8/11/2014 8:28:03 PM MLProcess Primary [1] (2) [Logger|Log~CAV~KEYPAD~Russound.Keypad.Next~P1=4, P2=1] from [Server] 8/11/2014 8:28:03 PM MLProcess Primary [1] Exiting MLProcess 8/11/2014 8:28:03 PM MLProcess Primary [1] Exiting MLProcess 8/11/2014 8:28:08 PM MLProcess Primary [1] (1) [Russound.Keypad.Previous|4~1] from [Server] 8/11/2014 8:28:08 PM MLProcess Primary [1] (2) [Logger|Log~CAV~KEYPAD~Russound.Keypad.Previous~P1=4, P2=1] from [Server] 8/11/2014 8:28:08 PM MLProcess Primary [1] Exiting MLProcess 8/11/2014 8:28:08 PM MLProcess Primary [1] Exiting MLProcess
Attached is an image of my AV section with the CAVs defined. Am I not doing something right or does this sound like a bug?
randyf
Fri Aug 15, 2014 1:16 pm
Since I have two CAV units, I decided to shut one of them down to see if the zone/command macro problem was related to having two CAV units but with just one unit running, I was seeing the same problem.
I also started just pressing each button on a keypad to see what would happen and for the Pause button, I received the following error:
8/14/2014 6:44:13 PM ProcessResponse Event Message [F0 00 00 7F 00 01 00 05 03 02 00 01 02 04 03 6E 00 00 00 00 00 01 09 F7] 8/14/2014 6:44:13 PM ProcessResponse Uno Pause Button Released. [6E] 2/0/1@4/3 8/14/2014 6:44:13 PM MacroExists Looking for Russound.Keypad.Pause 8/14/2014 6:44:13 PM ProcessResponse Error at ProcessResponse at line #3015 - 'MLServer.frmMain' does not contain a definition for 'cmdReceive'
Dave - any ideas?
