Generic IP Camera Driver
Thu Jan 17, 2013 4:45 pm
A new Generic IP Camera driver was released today. This is a universal driver that should work with all IP based cameras. Once you define the camera in Family Manager you would then go into the GenericIPCam driver and set up the various URLs for the camera commands. See the attached images for a Foscam example. Let us know how it works for you.
Generic IP Camera Setup
greyt
Re: Generic IP Camera Driver
Thu Jan 17, 2013 5:20 pm
Did the Panasonic cameras get direct support in the existing V4 driver. If not do you know what URLs need to go into the new generic driver to support them?
Thu Jan 17, 2013 5:42 pm
These should work for Panasonic cameras
StartScan http://<<ipaddress>>/nphControlCamera?Direction=PanScan Center http://<<ipaddress>>/nphControlCamera?Direction=HomePosition Tilt Down http://<<ipaddress>>/nphControlCamera?Direction=TiltDown Pan Left http://<<ipaddress>>/nphControlCamera?Direction=PanLeft Pan Right http://<<ipaddress>>/nphControlCamera?Direction=PanRight Tilt Up http://<<ipaddress>>/nphControlCamera?Direction=TiltUp Goto Preset http://<<ipaddress>>/nphControlCamera?Direction=Preset&PresetOperation=Move&Data=<<p1>> Live Image / Snapshot Image http://<<username>>:<<password>>@<<ipaddress>>/SnapshotJPEG?Resolution=640x480&Quality=Standard
greyt
Thu Jan 17, 2013 5:46 pm
Thanks Dave.
greyt
Fri Feb 01, 2013 6:09 am
I am just setting up snapshot viewing, I cannot see a way of deleting the current image that you are viewing, there appears to be no variable to number the image being viewed. There is a variable {{video_1_imagenumber_server}} but this contains the total number of images, should this variable be showing the number of the image being showed since there is already a variable {{video_1_totalimages_server}}for this.
Fri Feb 01, 2013 10:36 am
There's another update to that driver coming in the next couple of days that addresses that issue. Hand on for that update.
egamez
Sun Feb 03, 2013 10:22 am
Hi
I am testing it for a Panasonic camera.i can get the snapshot image in Mainlobby however when i use liveimage URL I get a black screen but URL works fine in my firefox browse
Is there any limitation with live images or is there a specific button library or button config I should use?
Thanks in advance for your help
Sun Feb 03, 2013 1:06 pm
Yes there are limitations with live images in Mainlobby. A lot of the new cameras are using streaming jpeg format and the MainLobby jpeg loaded object has a hard time with some of the codecs used in the streaming jpegs. Under those circumstances you need to use the static image and set it to reload.
greyt
Sun Feb 03, 2013 1:17 pm
CinemarDave wrote:Yes there are limitations with live images in Mainlobby. A lot of the new cameras are using streaming jpeg format and the MainLobby jpeg loaded object has a hard time with some of the codecs used in the streaming jpegs. Under those circumstances you need to use the static image and set it to reload.
The best I could come up with a video stream for my Panasonic was to use the web object and point it to
http://<<ip address>>/ImageViewer?Mode=Motion&Resolution=320x240&Quality=Standard&Interval=10&Title=1
only issue is you cant resize the image (even if you change the resolution in the URL). Technically it can be done, just need to spend some more time with it....
egamez
Sun Feb 03, 2013 3:20 pm
Tks folks
David is it and expected improvement?. How can i identify the web object within mainlobby ? To test the snapshot i used a mls scene from library 0028 but i am not sure if its a web object
Tks again
egamez
Sun Feb 03, 2013 7:50 pm
Hi Greyt
I tried you url but even working on my firefox browser its not still showing up on mainlobby so is there any dependency on my deafaul internet browser or the object being used?
Tks
greyt
Mon Feb 04, 2013 3:31 am
egamez wrote:Hi Greyt
Tks
I am using the weblobby object for this URL.
egamez
Mon Feb 04, 2013 7:02 am
Good morning Greyt
Tks . Can you point me please to where the web object is located? I dont see it listed explicitly in any of the library show up by mainlobby
Tks
greyt
Mon Feb 04, 2013 7:07 am
egamez
Mon Feb 04, 2013 8:03 am
Thanks GreyT
I figured out that I had to reinstall the Weblobby Library so its being show up on Mailobby. I tried your URL on a MLWebWindow and its working--
By the way the MLWeb Server App is not longer required just the library.
I will continue to test the MlGeneric IP Driver and reporting any issue
Tks
