spage
Re: V4 Elk Driver
Wed Dec 23, 2015 5:19 pm
I have an interface with my lights and the M1 and was wondering if it is possible to trigger my lights though this plugin?
thanks,
Simon
Re: V4 Elk Driver
Thu Dec 24, 2015 12:28 pm
What types of lights are connected to the Elk? Z-Wave, UPB, Insteon?
spage
Re: V4 Elk Driver
Sat Dec 26, 2015 6:28 am
Clipsal C-Bus.
Re: V4 Elk Driver
Sat Dec 26, 2015 11:45 am
Would controlling those lights fall under the Elk PLC command set? The Elk driver has commands for controlling lights through the PLC command set but I don't think we've ever had a customer who was controlling lights via the Elk.
spage
Re: V4 Elk Driver
Sat Dec 26, 2015 6:52 pm
No the ELK uses ASCII Protocol commands to communicate with CBUS.
On, OFF and set to xx%.
Simon
Re: V4 Elk Driver
Mon Dec 28, 2015 9:12 pm
Is that defined in ElkRP somewhere. Can you show an example?
spage
Re: V4 Elk Driver
Tue Dec 29, 2015 12:54 am
It's setup by importing the CBUS config file in ELKRP under Automation/Lighting. (ElkRP1.jpg)
ElkRP2.jpg is what it looks like once imported.
I include the manual for the interface and a copy of my CBUS config file, Owen.xml.
Simon
OWEN.zip
CBUS config file zipped
(5.45 KiB) Downloaded 132 times
Interface Manual.pdf
(1.11 MiB) Downloaded 114 times
Re: V4 Elk Driver
Mon Feb 29, 2016 9:37 am
CinemarDave wrote:Working on your system right now.
Back to the same problem with Climate1 and Climate2
From 12/22/15
Dave, you fixed the driver I believe for the ELk because it wasn't playing nice with the Nest and "Climate 1" and "Climate 2" - see the thread above for the date. I had to completely restart my server and reload everything. Unfortunately I updated all the drivers and the ELk driver shows a file date in July but this problem was fixed in December. Can you put the updated driver(s) in installation agent? [-o<
Re: V4 Elk Driver
Wed Mar 02, 2016 9:21 pm
Dave, I know you have a bunch going on. I updated everything and noticed the: Climate|xxx~Fan~Cycle does nothing in the ELK for climate control and Climate|xxx~Fan~Off is missing for some reason as a command. Climate|xxx~Fan~On does work.
Re: V4 Elk Driver
Thu Mar 03, 2016 8:37 pm
The driver supports Fan~on and Fan~off. Not sure why on would work and not off. What was in the log? Cycle is not supported.
Re: V4 Elk Driver
Sat Mar 05, 2016 11:13 am
It dislikes the off command in the ELk driver.
Re: V4 Elk Driver
Sat Mar 05, 2016 11:14 am
Since the command builder has no "Off" command listed, I'm assuming the xml for the command is not there.
Re: V4 Elk Driver
Thu Mar 10, 2016 5:05 pm
Sorry, in Elk the Fan only accepts On, Auto, Toggle. There is no true Off state. I suppose I could alias "Off" to "Auto"
Re: V4 Elk Driver
Thu Mar 10, 2016 5:46 pm
Toggle would work. I don't think it currently work though. I'll test it
Users browsing this forum: No registered users and 3 guests
