Aprilaire Device Driver
Sat Sep 22, 2012 8:02 pm
We just released a native V4 device driver for the Aprilaire thermostats. This driver is a member of the Climate family. It is a direct port of the V3 plugin with the command set modified to fit the new family structure. If you've got some of these give the new driver a test and let us know how it works.
AVDCORPNY
Re: Aprilaire Device Driver
Sun Feb 24, 2013 10:18 pm
Dave , the driver work ok , but the new v4 don't update status of the stat like to old v3 drive did , could you make this driver update status of stat, also found that the command set heat and cool point don't work . Thank you Mark
AVDCORPNY
Thu Mar 07, 2013 9:25 pm
AVDCORPNY wrote:Dave , the driver work ok , but the new v4 don't update status of the stat like to old v3 drive did , could you make this driver update status of stat, also found that the command set heat and cool point don't work . Thank you Mark
DAVE did you check why the command are not working and why stat are not update like the v3 plugin
Fri Mar 08, 2013 12:57 pm
Can you turn on logging to a file in the Aprilaire driver and restart MLServer. Then issue some commands. After that email me the Aprilaire event log. This driver is working for other customers not sure why it wouldn't work for you.
AVDCORPNY
Fri Mar 08, 2013 2:47 pm
dave driver is working, but it not update status like before and the command to setheat point and cooling point is not working , will send you log shortly
AVDCORPNY
Fri Mar 08, 2013 3:50 pm
AVDCORPNY wrote:dave driver is working, but it not update status like before and the command to setheat point and cooling point is not working , will send you log shortly
i have attached log
Aprilaire-3-8-2013.pdf
(20.29 KiB) Downloaded 122 times
Sat Mar 09, 2013 1:14 pm
There was incorrect syntax in the Command Builder xml file. The Set Point commands do not need the ~Set parameter. Use Client|1~HeatSetPoint~72
The updated driver has the updated Command Builder file.
AVDCORPNY
Sat Mar 09, 2013 2:16 pm
Dave could you fix the poll status of all stat, like v3 that check status of all stat about every 10 min ,also new command to setheat point works fine thank you
Texsun
Sun Jul 07, 2013 8:00 am
Will this driver support the 6504 Zone Controller (4 zones)?
Sun Jul 07, 2013 6:29 pm
In theory yes, but we won't know for sure until it is tested.
egamez
Sun Oct 20, 2013 10:39 am
Hi Texsum and Dave.
I am quite bit confused since the Aprilaire 6504 Zone Control does not seem to be controllable- I have take a look over the installation manual (attached) and not found any communicating port ( either RS232 or RS485). Even more the 6504 only supports 8570 Aprilaire thermostat which are not neither communicating enabled
So appreciate you clarify which Aprilaire devices are controllable by the MLS driver
Tks
6405_install_guide.pdf
(892.96 KiB) Downloaded 111 times
Sun Oct 20, 2013 5:00 pm
The driver supports all the 8000 series thermostats. Usually you have to have one of the Aprilaire 8811 RS-485 to RS-232 Protocol Adapter for the 8870 to connect the RS-485 buss the thermostats sit on to something that the PC can connect too. I assume you could wire one of these into that controller. In all cases the driver will be talking directly to the individual thermostat.
egamez
Mon Oct 21, 2013 8:21 am
Thanks Dave its what I thought in deed the 8870 has been discontinued and only the 8800 its availabe. The 6504 zone controller its not enabled with a communication port neither the required thermostat
jeffdoo
Sun Mar 09, 2014 3:27 pm
I am in the process of moving almost all home automation control to Cinemar as my primary solution (with ISY), so you are probably going to hear a lot from me.....
I have installed the Aprilaire thermostat driver but I seem unable to create thermostat or even have the driver settings stick between MLServer restarts.
I installed the driver, started MLServer, went to the Climate Family Manager, clicked "Add", created "Climate1"|"Aprilaire"|"Thermostat"|"COM4". I then went to the Aprilaire Driver (via "Show Driver") but I cannot do anything. The baud rate settings are both empty (so I click 19200) and a row exists for Climate1, so I set the "TStat Address" to 1, but nothing happens. I have 4 thermostats to be added (TStat 1-4, with 3 bedroom temp sensors on TStat 2) but I cannot figure out how to add them, right clicking anywhere in the thermostat window does not allow me to add/delete.... And, when I restart MLServer the settings in the driver are gone (no baud rate and the TStat for the first entry is gone).
Here is the log file from the driver with my multiple attempts:
3/9/2014 2:26:05 PM TimerRefresh Family members changed. Refreshing Devices 3/9/2014 2:26:20 PM ProcessCommand Cmd=[1~Status] Client=[] 3/9/2014 2:26:20 PM ProcessCommand Error at ProcessCommand at line #361 - Value cannot be null. 3/9/2014 2:30:58 PM TimerRefresh Family members changed. Refreshing Devices 3/9/2014 2:31:17 PM ProcessCommand Cmd=[1~Status] Client=[] 3/9/2014 2:31:17 PM ProcessCommand Error at ProcessCommand at line #361 - Value cannot be null. 3/9/2014 2:32:12 PM ProcessCommand Cmd=[1~Status] Client=[] 3/9/2014 2:32:12 PM ProcessCommand Error at ProcessCommand at line #361 - Value cannot be null. 3/9/2014 2:44:44 PM TimerRefresh Family members changed. Refreshing Devices 3/9/2014 2:45:39 PM TimerRefresh Family members changed. Refreshing Devices 3/9/2014 2:45:54 PM ProcessCommand Cmd=[1~Status] Client=[] 3/9/2014 2:45:54 PM ProcessCommand Error at ProcessCommand at line #361 - Value cannot be null. 3/9/2014 3:07:36 PM ProcessCommand Cmd=[1~Status] Client=[] 3/9/2014 3:07:36 PM ProcessCommand Error at ProcessCommand at line #361 - Value cannot be null.
Thoughts as to what I am doing wrong?
- Jeff
Sun Mar 09, 2014 4:03 pm
In Family Manager have you entered the thermostat number in the address column? Aprilaire thermostats must be addressed by number.
