simonmason
Automatically restarting streams
Thu Sep 08, 2011 6:03 pm
Recently I have noticed that my stream playback is interrupted and doesn't restart automatically. Ever since Irene (may or may not be related) the playback will periodically stop. When I check the now playing it will sometimes show "Acquiring stream" or nothing. Hitting the play button will immediately reconnect the stream. Is there any way to have it restart these streams automatically?
Simon D. S. Mason
Re: Automatically restarting streams
Thu Sep 08, 2011 8:41 pm
Not at this time. You'll have to manually restart them.
sonypoolplr
Fri Sep 09, 2011 11:36 am
Just wondering if there is a variable that shows the now playing as "Acquiring stream". If so, maybe an automation rule to state if the variable is in this condition for say more than a minute to issue the play command again.
Just a thought, as I don't know if this variable even exists in the system.
simonmason
Fri Sep 09, 2011 6:23 pm
That is a good idea.
Simon D. S. Mason
simonmason
Sun Sep 11, 2011 9:45 pm
I was looking into this a little further. I notice that when the player stops playing the stream it shows "Acquiring stream..." in {{music_currentartistname_{{music_activemusicsourcenumber_{{clientname}}}}}}.
I created the following automation rule:
whenever music_currentartistname_2 changes value
and music_currentartistname_2 contains ...
then MLMusicLobby|2~TogglePlayPause
I have not had the stream stop yet so I don't know if this will work?
Simon D. S. Mason
simonmason
Tue Sep 13, 2011 9:21 am
This did not appear to do anything so I modified it as follows:
then Macro|MLMusicLobby|2~TogglePlayPause!Setvariable|Streamdebug~Got it
I am hoping to see that it catches the "Acquiring Stream..." text and sets the variable?
Is my syntax correct for this? Thanks.
Simon D. S. Mason
Tue Sep 13, 2011 11:32 am
Make sure the MusicLobby plugin is not setting variables in "fast" mode. If it is no automation rules will ever get fired.
simonmason
Tue Sep 13, 2011 12:09 pm
It is - I just turned this back on. I did it to try and diagnose the issue with coverart not appearing for my radio streams. I will switch it back off. Other than that, is my syntax correct for the automation rule? Thanks.
Simon D. S. Mason
Tue Sep 13, 2011 12:24 pm
Your rule syntax appears to be correct.
Return to “MusicLobby 3.75”
