Blade
Issue with script with clientname parameter
Fri Aug 07, 2009 1:43 pm
I am trying to use the following script but it is not working.
I think it is dying trying to use a variable name as the parameter to the MLServer.GetVariable call.
Sub FixArtistBioDates (Params) dim client dim variableName dim theBornDate dim theDiedDate dim theNewBornDate dim theNewDiedDate dim splitArray dim monthName client = Params(0) ' fix born date variableName = "music_artistbio_born_" & client theBornDate = MLServer.GetVariable(variableName) if Len(Trim(theBornDate) ) > 0 then splitArray = Split(Trim(theBornDate), " ") if splitArray(1) = "1" then monthName = "Jan" elseif splitArray(1) = "2" then monthName = "Feb" elseif splitArray(1) = "3" then monthName = "Mar" elseif splitArray(1) = "4" then monthName = "Apr" elseif splitArray(1) = "5" then monthName = "May" elseif splitArray(1) = "6" then monthName = "Jun" elseif splitArray(1) = "7" then monthName = "Jul" elseif splitArray(1) = "8" then monthName = "Aug" elseif splitArray(1) = "9" then monthName = "Sep" elseif splitArray(1) = "10" then monthName = "Oct" elseif splitArray(1) = "11" then monthName = "Nov" elseif splitArray(1) = "12" then monthName = "Dec" end if theNewBornDate = monthName & " " & splitArray(2) & ", " & splitArray(0) MLServer.SetVariable variableName, theNewBornDate end if End Sub
ronsatter
Re: Issue with script with clientname parameter
Fri Aug 07, 2009 11:19 pm
Hi Blade,
I'm glad to see you tackling this. It has been on my wish list.
Just curious ... what happens when you use the actual data in place of the variable? Does the script work? Perhaps it doesn't like the substitution for the client name ... just throwing out questions. As you know, my scripting skills are pathetic ! #-o
Sat Aug 08, 2009 2:39 am
Your script is fine you just have a slight oversight. When calling GetVariable and SetVariable you have to make sure you convert the VBScript variables that are always of type "variant" to "strings" using the CStr() command. Your script should look like the following
Option Explicit Sub FixArtistBioDates (Params) dim client dim variableName dim theBornDate dim theDiedDate dim theNewBornDate dim theNewDiedDate dim splitArray dim monthName client = Params(0) ' fix born date variableName = "music_artistbio_born_" & client theBornDate = MLServer.GetVariable(cstr(variableName)) if Len(Trim(theBornDate) ) > 0 then splitArray = Split(Trim(theBornDate), " ") if splitArray(1) = "1" then monthName = "Jan" elseif splitArray(1) = "2" then monthName = "Feb" elseif splitArray(1) = "3" then monthName = "Mar" elseif splitArray(1) = "4" then monthName = "Apr" elseif splitArray(1) = "5" then monthName = "May" elseif splitArray(1) = "6" then monthName = "Jun" elseif splitArray(1) = "7" then monthName = "Jul" elseif splitArray(1) = "8" then monthName = "Aug" elseif splitArray(1) = "9" then monthName = "Sep" elseif splitArray(1) = "10" then monthName = "Oct" elseif splitArray(1) = "11" then monthName = "Nov" elseif splitArray(1) = "12" then monthName = "Dec" end if theNewBornDate = monthName & " " & splitArray(2) & ", " & splitArray(0) MLServer.SetVariable cstr(variableName), cstr(theNewBornDate) end if End Sub
However, I'll make sure the next version of MusicLobby creates these date variables in a more friendly format.
Blade
Sat Aug 08, 2009 2:11 pm
Thx Dave. I knew it was something simple.
Here is the command to call the script:
MLScript|Music_FixArtistBioDates~FixArtistBioDates~{{clientname}}
Here is the full script:
Sub FixArtistBioDates (Params) dim client dim variableName dim theBornDate dim theDiedDate dim theNewBornDate dim theNewDiedDate dim splitArray client = Params(0) ' fix born date variableName = "music_artistbio_born_" & client theBornDate = MLServer.GetVariable(cstr(variableName)) if Len(Trim(theBornDate) ) > 0 then splitArray = Split(Trim(theBornDate), " ") theNewBornDate = GetMonthName(splitArray(1)) & " " & splitArray(2) & ", " & splitArray(0) MLServer.SetVariable (cstr(variableName)), theNewBornDate end if ' fix died date variableName = "music_artistbio_died_" & client theDiedDate = MLServer.GetVariable(cstr(variableName)) if Len(Trim(theDiedDate) ) > 0 then splitArray = Split(Trim(theDiedDate), " ") theNewDiedDate = GetMonthName(splitArray(1)) & " " & splitArray(2) & ", " & splitArray(0) MLServer.SetVariable (cstr(variableName)), theNewDiedDate end if End Sub Function GetMonthName(monthNum) dim monthName if monthNum = "01" then monthName = "Jan" elseif monthNum = "02" then monthName = "Feb" elseif monthNum = "03" then monthName = "Mar" elseif monthNum = "04" then monthName = "Apr" elseif monthNum = "05" then monthName = "May" elseif monthNum = "06" then monthName = "Jun" elseif monthNum = "07" then monthName = "Jul" elseif monthNum = "08" then monthName = "Aug" elseif monthNum = "09" then monthName = "Sep" elseif monthNum = "10" then monthName = "Oct" elseif monthNum = "11" then monthName = "Nov" elseif monthNum = "12" then monthName = "Dec" end if GetMonthName = cstr(monthName) End Function
ronsatter
Sun Aug 09, 2009 12:12 am
Thx Blade!
Works like a charm. Now if there were only a way to distinguish between the artist meta data for a single performer and a group. Any ideas, anyone?
PS. Here's some screenshots from my new MUL scenes. (These are custom designed, using elements from 0026 graphics and my own elements)
The right vertical panel area is running a vacation slideshow from PhotoLobby while a real-time sequence of MusicLobby scenes was displayed.
I know ... my taste in music is sooo 50's :roll:
MUL Browse.jpg (742.22 KiB) Viewed 2744 times
MUL Search.jpg (637.65 KiB) Viewed 2744 times
MUL Now Playing.jpg (665.47 KiB) Viewed 2744 times
MUL Artist Bio.jpg (657.99 KiB) Viewed 2744 times
Sun Aug 09, 2009 10:17 am
Forget all that scripting stuff!! The best feature on Rons screen is the "User Tip" area!! 8)
Return to “MLScript”
