hakha4
Help with script,please
Fri Feb 20, 2009 1:29 pm
Hi!
Trying to write a script to set pathway for launching VLC with different locations. Could someone please look at code below and give me a hint whats wong,no errors when test but don't work. I'm calling the script with :
(scripname = SetVLC)
MLServeCmd.MLScript|SetVLC~"HTPC1"
and want the result in variable Vlc_plugin_path
Option Explicit
Sub SetPath (Params)
dim tmp_activezone
dim tmp_string
tmp_activezone = Params(0)
'tmp_activezone = "HTPC1"
If tmp_activezone = "Server1" Then
tmp_string = "C:\vlc_plugin\vlc_vb.exe"
End If
If tmp_activezone = "HTPC1" Then
tmp_string = "\\HTPC1\C:\vlc_plugin\vlc_vb.exe"
End If
If tmp_activezone = "HTPC2" Then
tmp_string = "\\HTPC2\C:\vlc_plugin\vlc_vb.exe"
End If
MLServer.SetVariable "vlc_plugin_path",tmp_string
End Sub
Is the way of calling wrong? Wrong thinking in code?
Regards Håkan
bigDvette
Fri Feb 20, 2009 8:12 pm
I'm not near my server, but in the wiki it says
MLServeCmd.MLScript|ScriptName for scripts that do not require parameters passed to them
or
MLServeCmd.MLScript|ScriptName~FunctionName~Parameter1~Parameter2~...ParameterN for scripts that require parameters passed to them
So if you want to pass params it looks like you need to call a function in the script.
bigDvette
Fri Feb 20, 2009 8:15 pm
try
MLServeCmd.MLScript|SetVLC~SetPath~HTPC1
no quotes on the variables and call the sub.
hakha4
Sat Feb 21, 2009 3:04 am
Thanks a lot!
MLServeCmd.MLScript|SetVLC~SetPath~HTPC1 did the trick. Now I can go on doing stuff
Regards Håkan
hakha4
Sat Feb 21, 2009 6:36 am
Hi BigDvette!
Can I ask you or someone else another question?
I don't really fancy the TT-player so I'mworking on a solution for VLC and I'm almost there. I have integrated VLC in a small VB6 program so I really can do what I want with the player. (I've done quite a lot of vb-programming but not yet got the feeling for MLServer commands!)
In DvdLobby I'm launching the command :
Macro|MLServeCmd.MLScript|SetVLC~SetPath~{{clientname}}|SetVariable|media_{{clientname}}_transport_source~VLC!MLDVDLobby|MakeSource~{{media_{{clientname}}_transport_source}}!AV.AS{{media_{{clientname}}_activeplayer}}|MLPause|1!MLFileOpen|{{vlc_plugin_path}} ~<<file>>
Thr aim is to set the variable vlc_plugin_path depending on what client and launch the vlc_vb-program to play the file.. If I lanch the SetVLC script from command prompt it's changing variable as wanted. The problem in the DvdLobby command is that :
seems to be translated as one entity by server.
Is it wrong to launch a script from here?
Wrong delimiter beetwen statements?
Much appreciate if someone could give me a hint
Regards Håkan
bigDvette
Sun Feb 22, 2009 12:22 pm
I think the problem is in your Macro command delimeter
should be
Macro|MLServeCmd.MLScript|SetVLC~SetPath~{{clientname}}!SetVariable|media_{{clientname}}_transport_source~VLC!MLDVDLobby|MakeSource~{{media_{{clientname}}_transport_source}}!AV.AS{{media_{{clientname}}_activeplayer}}!MLPause|1!MLFileOpen|{{vlc_plugin_path}} ~<<file>>
after the setpath~{{clientname}} you are using a | not a ! and again before MLPause
If that is not it, maybe you can write it out in english what you are trying to do. ie.
Call MLScript to set variable xxxx to yyyy
set variable mediaxxxx to VLC
Are you tring to send that setvariable to the script?
hakha4
Mon Feb 23, 2009 1:38 am
Hi!
Thank's a lot again,it works now. I've been searching the WIKI to find out when to use the | and ! in commands but i haven't find it. What are the rules to build commands ?
Regards Håkan
bigDvette
Mon Feb 23, 2009 10:25 am
Glad it worked.
As for rules, I'd just say every command has a syntax and sometimes an alternate syntax as well (like different delimiters so you can nest commands).
When issuing multiple commands, you use Macro and the delimiter between commands is a !.
Most commands start with the pluginname then a | then the function or device in the plugin and use ~ for the rest of the delims. However, best to just look up each command and know the syntax using the wiki.
Return to “MLScript”
