bjdraw
Constant variables between Sub Routines
Wed May 21, 2008 6:54 pm
I'm working on a script that has several sub routines, that all share constant variables.
I've tried a few different ways, but I can't seem to get the multiple subs to work without specifying the variables in each sub routine.
I've tried declaring the variables before the sub, but it doesn't work. I've also tried using the const keyword, with and without the public option, but neither worked.
Is there any way to specify constant variables that would be valid in every sub in one script?
Ben Drawbaugh
How good can it be, if it isn't HD?
bigDvette
Wed May 21, 2008 8:38 pm
I assume you are calling subroutines in a script and I think MLScript treats them as independent units much like if you had built functions in an excel workbook and called them from a form.
YOu may try the Global or Public keyword (can't remember which) or you can call a single sub with a parameter that tells it which function you really want and set the variables in the controlling routine. That would also allow you to simply have 1 authentication message section for all the ISY commands you are trying to create :-)
bigDvette
Wed May 21, 2008 8:43 pm
for clarity create a script with the following subs
declare variables
sub InitateISYAction (usr, pass, serverIP, device, command)
set variables
initiate authentication message
if command is DON
call donISYAction (serverIP, device, command)
if commandis DOF
call dofISYAction (serverIP, device, command)
end if
end sub
sub donISYAction (a,b,c)
Return to “MLScript”
