bjdraw
Sample2 example syntax?
Wed May 21, 2008 3:42 pm
Based on the wiki, I issued this command for sample 2.
MLScript|Sample2~TestSub~Ben~Drawbaugh
To which I expected to see a variable
AATEST1 = Ben-Drawbaugh
But instead I get the "Incorrect number of parameters passed to function TestSub"
To double check, I deleted the variable to ensure I was creating it each time.
What is the correct syntax?
Ben Drawbaugh
How good can it be, if it isn't HD?
Wed May 21, 2008 5:14 pm
You need to change one line in the script
Change
If Ubound(Params) = 1 then
To
If Ubound(Params) = 2 then
bjdraw
Wed May 21, 2008 5:34 pm
That's pretty funny, I never once considered the possibility that I was doing it right.
Works now.
Ben Drawbaugh
Return to “MLScript”
