bigDvette
doPlugin command in MLScript
Thu Apr 03, 2008 11:43 pm
Can someone give an example of how to call the doPlugin command when the plugin requires multiple parameters.
MurrayW
Re: doPlugin command in MLScript
Mon Sep 01, 2008 2:15 am
bigDvette wrote:Can someone give an example of how to call the doPlugin command when the plugin requires multiple parameters.
And in another thread, Ron asked a similar question:
http://www.cinemaronlineforums.com/foru ... ugin#81044
I'm starting to play around with MLScripts and have the same question. For example if within a script I wanted to call this command:
MLServeCmd.MLDirectv|001~Key~Guide
, what would the doPlugin syntax be? And would doPlugin be better than the cmdreceive or cmdreceivepush syntax (ala Ron's question)?
Something like this?
MLServer.doPlugin MLDirectv, 001, Key, Guide
thanks,
Murray
Mon Sep 01, 2008 1:58 pm
You do not need to call doPlugin. You would simply say
MLServer.cmdReceive "MLDirectv|001~Key~Guide"
The only time you want to call doPlugin is if you are calling a function in a plugin that returns a variable. Very few plugings support this.
The difference between cmdReceive and cmdReceivePush is that cmdReceive gets executed immediately and cmdReceivePush places the command into MLServer's command queue to be executed in turn.
MurrayW
Mon Sep 01, 2008 2:11 pm
CinemarDave wrote:You do not need to call doPlugin. You would simply say
Thanks for the explanation...I spent a few hours last night working on scripts and I guess I am lucky that I picked MLServer.cmdReceive!
Murray
Return to “MLScript”
