bigDvette
Can we change the parameter delimiter?
Wed Apr 02, 2008 5:21 pm
If you use setvariable or MLTimer and want to call MLScript, you can't because you can't put ~ in a variable or when building the command for MLTimer. I see all kind of uses for MLScript, but the one that has me hung right now is that I'd like to be able to call it from MLTimer, but I need parameters to make this work efficiently. A lot of the DVDLoby stuff doesn't use ~ for delimiters. Can this be a change for MLScript too?
Wed Apr 02, 2008 11:38 pm
Version 3.0.482 of MLServer includes a version of MLSript that will accept ?? as delimiters instead of the traditional ~. You cannot mix ~ and ?? in one MLScript command. But either will work.
bigDvette
Thu Apr 03, 2008 9:02 am
WOOT!
Thanks Dave!
bigDvette
Thu Apr 03, 2008 11:50 pm
This has solved my issues Dave. Thanks. Of course I made the classic MLInstaller mistake and clicked install before I clicked download and it took me an hour before I realized I hadn't updated MLServer, but all is good now.
For those that want my script I have a simple 2 function script. Someone said you could actively debug, but I haven't figured out how to do that yet.
From MLLigthing, I set an event to the On condition of the lights I want to monitor like my sons room and I use the follwoing command.
MLServeCmd.MLScript|LightingTimerCommand??SetTimer??3??20??024
The first parameter is the timer number I want to set and the second is the number of minutes for the timer and the third is the light number or name (my names aren't unique). This is way easier than managing the whole command in MLLighting due to the single line edit box for the command.
When you call SetTimer it sets a MLTimer with a command to call MLScript again. I had to do this because you can't put ~ characters in the MLTimer Command, so I call MLScript and have it call MLLighting.
-------------- LIGHTINGTIMERCOMMAND SCRIPT ---------------------
Sub SetTimer (Params)
MLServer.cmdReceive "MLServeCmd.MLTimer|SetTimer~" & Params(0) & "~NoRepeat~" & Params(1) & "~minutes~MLServeCmd.MLScript|LightingTimerCommand??LightOff??" & Params(2) & "~enable"
End Sub
Sub LightOff (Params)
MLServer.cmdReceive "MLServeCmd.MLLighting|Off~" & Params(0)
End Sub
Return to “MLScript”
