mwebster
alternative
Sat Feb 23, 2008 5:19 pm
Cinemar doesn't let you access com ports from scripts, right? So to write scripts that utilize the com port on my computer I'd have to buy another plugin? Seems odd, maybe I'm wrong.
I've written scripts in vb, lua, and perl. They're ok for very simple stuff, but I've found that using the free microsoft stuff (vb or c express) I can do more and it's easier to develop the code. I'm sure there are reasons scripting is cleaner from Cinemar's end, but I would pay for a good way to get data in and out of my vb apps and mlserver, but wouldn't pay for this plugin. Currently I use the tcpsend plugin and command line to get things back and forth.
I think that letting the users do more and share the application specific stuff and give the professional developers more time to enhance the core apps would be a good thing for everyone.
Not complaining, I think the stuff I've bought has been a good value.
Matt
Sat Feb 23, 2008 6:08 pm
Matt, are u using MLDatabase? Maybe that might help integration with your apps?
Yes, no access to hardware via scripts. Today would have to be via a MLGenericDevice plugin (which the script capability was just modded today to match MLScript syntax et al).
bhiga
Sat Feb 23, 2008 10:31 pm
Actually there is a way to access com ports via VBScript - I've done in the past to drive an LCD character display and Primera Composer autoloader. Unfortunately I lost that code in a crash, so I'm still trying to replicate it.
MLGenericDevice would be a better way to go as it's better integrated and portable.
- Brandon
My MainLobby stuff (plug-ins, screenshots, etc)
mwebster
Sun Feb 24, 2008 12:19 am
smoothtlk,
I haven't tried MLDatabase, but I'll check it out again. I haven't had a need to update groups of mlserver variables quickly.
Matt
mwebster
Sun Feb 24, 2008 12:34 am
bhiga,
If you run across the method for accessing com ports via VBScript, I'd love to hear some details. I searched, but couldn't find a method. I've done it in HomeSeer, but they provide the ability.
I haven't looked at it much, but I don't think I need any of the advanced features of MLGenericDevice. I just want to be able to use the com port on my pc from ML.
worf83
Thu Aug 28, 2008 10:50 pm
bhiga wrote:Actually there is a way to access com ports via VBScript - I've done in the past to drive an LCD character display and Primera Composer autoloader. Unfortunately I lost that code in a crash, so I'm still trying to replicate it.
Brandon,
Have you been able to replicate the code using VBScript ?
TIA
AL
Thu Aug 28, 2008 11:35 pm
This should give you a leg up.
REM VBScript Example of using MSComm control for send and receive REM --------------------------------------------------------------------------- ' NOTES: ' This is a complete example of using the MSComm control distributed with Visual ' Studio 6 to both send and receive data. The received data is stored in a text ' file. Both binary and printable text characters can be received. The text file ' is stored in the same directory as this script. The number of characters to ' receive before ending the script is settable through 'MyThreshold'. ' For maximum efficiency of burst-mode data, the event handler buffers the ' incoming data before writing it to the file. Since it is not possible to ' know how many characters may be in the MSComm control's input buffer, the ' only sure way of knowing how many characters are received is to accumulate ' the count through a call to the control's InBufferCount property. While this ' may appear to be counter-intuitive, the control does not interrupt the program ' on every received character. It is not possible to know how many characters ' are waiting without using the InBufferCount property. When the Input() ' method is called, it will take InBufferCount number of bytes (all of them) out ' of the input buffer if the InputLen property is set to '0'. ' After the threshold number of bytes are received, the event handler processes ' the contents of the receive buffer by writing the contents to the log file ' two bytes at a time with commas separating each pair of bytes. Option Explicit Dim objTest ' MSComm control reference pointer Dim objFSO ' file system reference pointer Dim objLogFile ' file pointer Dim s ' general purpose string Dim path ' path to current directory Dim msg ' message sent out of comm port Dim flag ' indicates whether or not script continues Dim rxCnt Dim rxBuf Dim i const logfile = "\log.txt" ' file where received data is stored const MyPort = 1 ' COM1 const MyBaud = "57600" ' bps rate const MyThreshold = 6 ' how many characters to receive until done const comEvSend = 1 ' enumeration of comm events const comEvReceive = 2 const comEvCTS = 3 const comEvDSR = 4 const comEvCD = 5 const comEvRing = 6 const comEvEOF = 7 const comInputModeText = 0 ' enumeration of input mode constants const comInputModeBinary = 1 flag = 0 ' keep program running until comm event rxCnt = 0 Set objFSO = CreateObject _ ("Scripting.FileSystemObject") ' create a file system object path = objFSO.GetAbsolutePathName ("c:")' get the path to this directory Set objLogFile = objFSO.CreateTextFile _ (path & logfile, True) ' create a text file in local directory Set objTest = WScript.CreateObject _ ("MSCOMMLib.MSComm", "[/b]MSCommEvent_") ' second parameter (MSCommEvent_) + ' name of event (OnComm) creates the ' event handler that is called when ' the event fires objTest.CommPort = MyPort ' select a port to use objTest.InputLen = 0 ' if = 0, will retrieve all waiting chars objTest.InputMode = comInputModeText ' causes Input() to return string (not array) objTest.RThreshold = 2 ' must be non-zero to enable receive objTest.PortOpen = TRUE ' open COM port for use s = MyBaud & ",n,8,1" ' settings: baud,parity,bits,stop in BSTR objTest.Settings = s ' send to COM port msg = "Test Message " objTest.Output = msg ' send test message out of port While flag = FALSE ' put script in idle until comm event Wscript.Sleep (1000) Wend objLogFile.Close ' close log file objTest.PortOpen = FALSE ' close port Wscript.DisconnectObject objTest ' destroy object Wscript.DisconnectObject objFSO ' destroy object Wscript.DisconnectObject objLogFile ' destroy object Set objTest = Nothing ' uninitialize reference pointer Set objFSO = Nothing ' uninitialize reference pointer Set objLogFile = Nothing ' uninitialize reference pointer Wscript.Echo "Script completed." REM --------------------------------------------------------------------------- Sub MSCommEvent_OnComm ' OnComm event handler Select Case objTest.CommEvent Case comEvReceive rxCnt = rxCnt + objTest.InBufferCount rxBuf = rxBuf & objTest.Input If rxCnt >= MyThreshold Then For i = 2 To MyThreshold Step 2 objLogFile.Write (Mid (rxBuf, i - 1, 2)) objLogFile.Write (",") Next flag = TRUE rxCnt = 0 End If Case Else End Select End Sub
worf83
Thu Aug 28, 2008 11:40 pm
Thank you very much for the script. I really appreciate all your help.
AL
mwebster
Sat Aug 30, 2008 2:00 am
Thanks for the example. A post above from Cinemar says:
I guess it wasn't true.
One concern I have about the example is this:
Wend
Will this hang mlserver for one second? I guess I'm not clear on how the script engine works. Is each script ran in its own thread independent of mlserver?
Also, is there a way to write to mlserver's event log from a script? If so, I could integrate my dsc security stuff into mlserver, which would be great.
Sat Aug 30, 2008 2:26 am
This script is not a good example of practical use. You cannot put any script into a loop like this because it will hang MLServer. You would not want to try to build a two-way plugin using script.
You can write to the MLServer event log using script.
MLServer.LogMLEvent SourceName, SourceEvent, LogLevel
Where:
SourceName = Usually the name of the script that is running
SourceEvent = The descriptive text
LogLevel = a number representing the event status
0 = Error
1 = Info
2 = Vebose
3 = Verbose Trace
mwebster
Sat Aug 30, 2008 12:43 pm
This is what I need to do. What methods are available for me to do this?
Return to “MLScript”
